65 Pages«<1516171819>»
#321 Posted : Tuesday, March 28, 2017 1:42:04 PM(UTC)
Here's the log file but it is useless Elgarf.
Blank UTC project, new vMix project with only a NDI source > I just recorded the crash so that you can see I'm not dreaming :
File Attachment(s):
2017-03-27.log.txt (6kb) downloaded 17 time(s).
#322 Posted : Tuesday, March 28, 2017 2:07:22 PM(UTC)
I just tried the same thing on my vMix host (win10) with freshly installed UTC (never used before on this machine) > same thing
I also tried on another computer with win7 > same thing
The host I usually use UTC on is win8 (the one for the video)
All are 64 bits pro
Maybe some other users could check ? > just try what I do in the video, it takes 1 minute
elgarf
#323 Posted : Tuesday, March 28, 2017 2:09:13 PM(UTC)
elgarf
Russian Federation
Was thanked: 229 time(s) in 129 post(s)
@DWAM, looks like I fixed it, re-download from the first post, please.
thanks 1 user thanked elgarf for this useful post.
DWAM on 3/28/2017(UTC)
#324 Posted : Tuesday, March 28, 2017 2:29:38 PM(UTC)
[img]http://t1.gstatic.com/images?q=tbn:ANd9GcR9zFgTAlujgbqnxqeQXh1GpBYzNW9mDpBHeFgLxzBxQq6JRnnJwTbzbuw[/img]
Great! It works now on all 3 OS!
Nice the isGroup option in functions.xml! Thanks
corporatejames
#325 Posted : Wednesday, April 5, 2017 6:26:48 PM(UTC)
corporatejames
Hi elgarf
I loaded UTC on a friends computer last night but noticed the functions.xml file was not loading in the dropdown for commands
of buttons etc.
If load my template everything works but can't change or add new buttons as this list doesn't load. This occurs on new fresh template as well.
Works fine on all my computers. Permissions seem all good for directory.
Any idea?
UTC has been working great thanks
Regards
James
elgarf
#326 Posted : Thursday, April 6, 2017 12:20:31 AM(UTC)
elgarf
Russian Federation
@corporatejames, can you tick "Enable Log", restart UTC and send me log file? It should help me to realize what happened.
elgarf
#327 Posted : Wednesday, April 12, 2017 8:15:03 AM(UTC)
elgarf
Russian Federation
Some additions to scripting (for advanced users =))
1) You can make variables in scripts (but they work only in one button scope, sorry).
2) There is new "HasVariable", "Condition", "ConditionEnd" commands, so you can make that some commands will execute only if condition is true. There is no logical operands like OR/AND, but you can make something like that by combining Condition and GoTo commands.
3) Now string parameter can handle expressions, so 1 + 1 give you 2, if you need exactly 1 + 1, you must enquote it, so it will be '1 + 1' (with quotes).
4) I've sorted script commands.
Condition is special command, because it has two input parameters, and special condition parameter.
You can access state/input variables by adding @ symbol before path. For example, if you need access input (which is title) text at index 0, you must write:
@Inputs[{0}].Elements[0].Text
Note, that {0} is substitution for Input 1 and {1} is substitution for Input 2 GUID.
Elements array is array of all input elements like text, overlay, etc. All parameters named from small letter into result of "http://127.0.0.1:8088/api?" are capitalized. So you need to write "Name" instead of "name", etc.
If you write path from "@" you can't use expressions =( but you can put value from path to variable.
Variables set from indexes, but in expressions them named with prefix "_var", so if you need access to variable 0, you should write _var0.
If you use UpdateInternalButtonState function, button must be state dependent.
If you can test existing projects with this version and all ok, I make it as main version.
Download
Also I made small audio reactive sample, you just need to place input with audio in the first Input parameter of condition.
Download sample
#328 Posted : Wednesday, April 12, 2017 8:55:16 AM(UTC)
Yesssssssssssssssss!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks Elgarf! I'll test this right away!!!!!!!
elgarf
#329 Posted : Wednesday, April 12, 2017 9:14:44 AM(UTC)
elgarf
Russian Federation
@DWAM, remember, that this is very simple automation feature, you can automate some processes, but don't make scripts very huge)
#330 Posted : Wednesday, April 12, 2017 9:36:36 AM(UTC)
I'll try to remember that when I will have understood how this works!
When I first told you about adding variables and parameters, I had ideas about passing parameters and variables from a widget to another one (like when we call a function or a sub in a script) but here it's quite different so I first need to figure out what can be done with it.
спасибо
elgarf
#331 Posted : Wednesday, April 12, 2017 9:53:32 AM(UTC)
elgarf
Russian Federation
Yep, that's works another way, because for populating variables across widgets I need completely rewrite UTC) or it will be not very good for support.
You can use vMix state to transfer variables across scripts if you really need this.
elgarf
#332 Posted : Wednesday, April 12, 2017 11:42:16 AM(UTC)
elgarf
Russian Federation
I realized that I broke Timer command, it fixed now. The link is the same...
Download
BTW, my dream come true) I had two scoreboards onto volleyball game:
1) score with current set
2) score with all sets
In the past I needed to write score into second scoreboard manually, because UTC don't know about current set number. Now I make it automatically =)
#333 Posted : Wednesday, April 12, 2017 12:16:22 PM(UTC)
Tried your audioreactive sample VMC file
First 127.0.0.1 is "hard-coded" in the VMC which makes remote UTC loose connection to vMix
Solved by changing the IP address by hand with text editor.
Did as explained above "you just need to place input with audio in the first Input parameter of condition."
I took me a while to understand but it works. To make it "clearer" :
- Take 1 video input in vMix (not cameras because F1Meter is never -or always- at 0)
- Send this video to PROGRAM and select it as input 1 in the sample Widget
- When the video ends, the F1Meter goes to 0 which makes the QuickPlay automatically
BUT !!!
- as long as the script remains active in UTC (the little square box is white) it's impossible to switch anything in vMix
- when pressing the little white square to stop the script manually, any previous switch done (which did not work before) will be done...
It seems we need a stop routine at the end of your script Elgarf. Don't know yet which method is the best way to go
Sounds good! I had the same issue with tennis sets. Interesting challenge! ;o)
elgarf
#334 Posted : Wednesday, April 12, 2017 12:57:21 PM(UTC)
elgarf
Russian Federation
Strange that nobody expect this before =) I always work on local machine, but changing IP/Port does not affect on UpdateState if vMix was started before UTC... Now fixed, but I wait for some another bugs)
That's only example. I personally add Audio Input (from intermal mic) and two Color inputs for switching.
For sets I added hidden text field into one of my titles, which take value from range 0-4.
Then I made five buttons, each for corresponding set (some limitations, because I can't use variables as Elements indexes, otherwise I could make a loop).
Each button has script, that check set number and copy values from first scoreboard to corresponding place in second they are StateDependent, so they use shared state special for buttons, but not main UTC state (which should be mostly static).
There is also button with loop, that updates internal button state and executes scripts for actualizing each set score. That's not instant (it's better to make some delays between updating state), but better than making it manually).
Button State is shared between buttons, so you can update it once anywhere.
Siroki
#335 Posted : Tuesday, April 18, 2017 6:08:29 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Hi guys,
I don't wanna make new topic for this, maybe you know the answer:
How to make in scoreboard HALF TIME, during match, after goal is scored etc to make on titles moving background below or above bottom scoreboard.
I mean when you on soccer match enter scorer name, or two scorers, three scorers so background moves/grows..Something like this:
Bottom right picture, its not big but I think you can see what I mean
thx
#336 Posted : Tuesday, April 18, 2017 6:44:19 AM(UTC)
Hi Marko
I think the easiest way is simply to use SetText and SetImage commands.
Make a XAML which has 5 or 6 potential scorers for each team, each on a new line. A line is a background image and text
At first all values are set to "nothing"
Then in UTC create 5 or 6 text widgets for both teams and map them to your title
When there is a goal enter scorer name and time
Now you can use Conditions to make automatic display of this area elements, but it was possible before already simply from buttons
Check this video I did on how to build a dynamic scorebug, I would use the same method for what you want.
https://forums.vmix.com/...ts&m=35051#post35051
Guillaume
Siroki
#337 Posted : Saturday, April 22, 2017 3:24:44 AM(UTC)
Siroki
One question:
Did anyone tried to setup timers for handball? The main timer that goes to 30 minutes and 2 minutes of penalties for players but in that way so you don't need to start multiple timers only the main one and the penalties are synco?
thx
digitalalps
#338 Posted : Saturday, April 22, 2017 3:32:11 AM(UTC)
digitalalps
I did it with the handball timers.
Timer for the game
2x timer for penalty minutes per team
When the time is stopped, the penalties are also stopped
If the time continues, the active penalties continue
Can you look for the template this afternoon
#339 Posted : Saturday, April 22, 2017 3:54:36 AM(UTC)
Hi
I have made a tutorial for sync timers here : https://forums.vmix.com/...ts&m=34908#post34908
You can also watch this video (for ice hockey) which demonstrates this use case :
Guillaume
digitalalps
#340 Posted : Saturday, April 22, 2017 5:14:38 AM(UTC)
digitalalps
Here a screenshot for handball settings i you want to get theme send me a pn
digitalalps attached the following image(s):
thanks 1 user thanked digitalalps for this useful post.
mburel1980 on 4/22/2017(UTC)
Guest (10), kayllastudio
