JonnyNoblett
#1 Posted : Sunday, April 2, 2017 7:55:06 AM(UTC)
JonnyNoblett
All I want to make animated titles for VMix - I know how to use AE which would be ok over NDI for most lower thirds but social media with photos included from Twitter is an important one we want to have.
Does anyone have any guides - explanations?
Jonny
#2 Posted : Sunday, April 2, 2017 7:58:45 AM(UTC)
Expression Blend is certainly the tool you need to check.
JonnyNoblett on 4/16/2017(UTC)
#3 Posted : Sunday, April 2, 2017 9:01:52 AM(UTC)
Step 1:
test vMix social and its available social titles and the Title mapping options in relation to the code of those titles and the social data
Step 2:
Check the examples ( and code) of the animated titles already present in vMix.
Also do a search in this forum as there are various post in regards to animated titles
Step 3:
Design a combination of both of the above to your specifications or wishes (animation and photos from twitter is a bit vague)
As Dwam said Expression Blend is certainly the tool you can use for designing or code manually ( need to learn some xaml regardless)
tkachuk.alex
#4 Posted : Wednesday, April 5, 2017 4:48:11 PM(UTC)
tkachuk.alex
Ukraine
Use Expression Blend to create a title you need.
Make a simple animation, it's not hard.
Tnen start vMix, add your title. Start vMix Social, and connect and map your title.
That's all )
thanks 1 user thanked tkachuk.alex for this useful post.
JonnyNoblett
#5 Posted : Sunday, April 16, 2017 12:19:49 PM(UTC)
JonnyNoblett
What version of Blend? I have Visual Studio 2017 with Blend installed but I have no idea where to start - does anyone have a tutorial?
For now I have made the titles I want with a combination of blank titles with just fields and also png sequences for the animation and used triggers to start them but I want to make real overlays/titles using blend.
#6 Posted : Sunday, April 16, 2017 12:35:55 PM(UTC)
Hi Jonny
Here's a video tutorial based on an older version but it might help anyway
Guillaume
thanks 2 users thanked DWAM for this useful post.
JonnyNoblett on 4/16/2017(UTC), madness on 4/18/2017(UTC)
JonnyNoblett
#7 Posted : Sunday, April 16, 2017 12:48:30 PM(UTC)
JonnyNoblett
Thanks, that is my first hurdle though, I cant seem to find any comparison workspace in the version I have. Id Blend Expression 4 available for download anywhere?
#8 Posted : Sunday, April 16, 2017 1:09:34 PM(UTC)
maybe here
There shouldn't be a problem using more recent versions of Blend. while i use a lot Blend for visual studio 2015
I sometimes use Blend 4 as that on can import illustrator and ps files
edit PS (see vMix help files)
All controls must be compatible with .NET Framework 3.5 SP1 (4.0 is not supported at this time)
JonnyNoblett
#9 Posted : Sunday, April 16, 2017 1:15:22 PM(UTC)
JonnyNoblett
I tried that download and it is a patch on the software so need to have the software first.
I have made a lot of PNG sequences so want I want to be able to do is overlay them in as a title and then overlay them out I have done it manually with trigger sbut feels clunky and seems risky.
