The Merg
#1 Posted: : Monday, April 10, 2017 10:50:19 AM(UTC)
The Merg
I am trying to set up vMix to have a stream from a camera as my input. I went to Add Input, selected More and then selected the option for Stream. I next selected RTSP over UDP and entered the address for my camera of rtsp://10.1.10.200. I also tried it as rtsp://10.1.10.200/1 to signify which stream to use. In both cases, I get the following error:
500 Internal Server Error
AddNewInput
I've included a screenshot of the error that I am getting.
The camera that we are using is a PTZOptics PT12x. I am running vMix v19.0.0.37 on a Windows 10 machine.
Any help that can be provided would be appreciated.
As a note, I can pull the stream into XSplit and then use XSplit as an input in vMix, but I'd rather eliminate that one step, if possible.
Thanks,
Merg
The Merg attached the following image(s):
vMix Streaming Input Error.JPG (73kb) downloaded 10 time(s).
xaver
#2 Posted : Monday, April 10, 2017 12:03:19 PM(UTC)
xaver
normaly you also need the port and the stream name
for my stream:
rtsp://192.168.1.155:1935/live/myStream
or
rtsp://xxx:1111@192.168.2.9:554/stream
on the other IP Cam
works perfect
#3 Posted : Monday, April 10, 2017 1:10:28 PM(UTC)
@ The Merg
The vMix help page list's it this way:
Stream Type
RTSP over UDP / RTSP over TCP
RTSP based sources such as the Teradek Cube and IP Cameras
Enter the URL in the following format: rtsp://0.0.0.0/stream1
Transport Stream over UDP
Select this option if a Transport Stream is being sent directly to the vMix machine over UDP
Enter the port number of the stream
Transport Stream over TCP
Selecting this option sets up vMix as a TCP server that can accept connections from remote streams
Enter the port to listen for connections
Transport Stream over TCP Pull
Select this option to connect to a remote Transport Stream server such as the Teradek Sputnik using the TCP protocol.
Enter the hostname and port of the remote Transport Stream server
http://www.vmix.com/help19/Stream.html
Hope that helps some.
sinc747
#4 Posted : Monday, April 10, 2017 2:20:15 PM(UTC)
sinc747
Have you used the PTZ Optics IP Address Settings Tool to change the IP address of the camera? That's generally what needs to be done first. Here's the tool: http://cdn2.hubspot.net/...ddress_Settings_Tool.zip
Otherwise the RTSP address you are using (rtsp://10.1.10.200/1) is in the correct format to use with vMix and PTZ Optics cams.
Good luck. Let us know how it goes.
- Tom
Guest (4)
