rudyengels
#1 Posted : Tuesday, April 4, 2017 12:09:18 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
I'm a brand new user of vMix and I have a small problem.
I'm using an external mixer (Allen & Heath ZED 12 FX) and want to bring my microphone into vMix.
My mixer is connected via USB. vMix is seeing my microphone when I select Add Input > Audio Input. Volume meters are working.
I'v followed the steps as described in http://www.vmix.com/help19/ but I just don't get any output in the Master or Recording.
What am I doing wrong?
Thanks for your help.
Kind regards,
Rudy Engels
rudyengels attached the following image(s):
#2 Posted : Tuesday, April 4, 2017 12:21:25 PM(UTC)
Hi lucky Rudy! ;o)
simply click the M icon in your audio input. (M stands for Master)
Your screenshots indicate that Buses A and B are not set.
Bien à toi
Guillaume
rudyengels on 4/4/2017(UTC)
rudyengels
#3 Posted : Tuesday, April 4, 2017 12:38:00 PM(UTC)
rudyengels
Hi Guillaume,
I've just followed the steps in the manual but changing the icon from bus A to M seems indeed to work. Only problem i still have is that the audio level of the recording is very low while my levels in vMix and mixer are perfect... Still a lot to learn but it seems the audio part of VMix is not that easy when working with an external mixer...
Merci!
Rudy
#4 Posted : Tuesday, April 4, 2017 12:50:47 PM(UTC)
Audio levels in vMix conform strictly to standards. I mean if your audio mixer outputs a -6 dB signal, vMix will receive -6 dB and stream or record -6 dB.
If your recording is low, the problem is either on your audio mixer or the way you mixed your audio input in vMix.
