Joined: 3/7/2017(UTC) Posts: 8 Location: Madrid, SPAIN
I have the issue with vMix. Does anyone knows the reason for this error?, Thanks
Nombre de la aplicación con errores: VMIX.EXE, versión: 19.0.0.37, marca de tiempo: 0x58d3af8e Nombre del módulo con errores: avmdevicecontrol.dll_unloaded, versión: 1.0.0.20, marca de tiempo: 0x524001eb Código de excepción: 0xc00001a5 Desplazamiento de errores: 0x00019d76 Identificador del proceso con errores: 0x3700 Hora de inicio de la aplicación con errores: 0x01d2a95a146b4c62 Ruta de acceso de la aplicación con errores: C:\Program Files (x86)\vMix\VMIX.EXE Ruta de acceso del módulo con errores: avmdevicecontrol.dll Identificador del informe: 27c1d877-a82d-4556-bb73-f650d31bd2e3 Nombre completo del paquete con errores: Identificador de aplicación relativa del paquete con errores:
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hola José
can you tell us what you do when this error occurs?
¿Qué se hace cuando se produce el error?
DWAM wrote:Hola José
Disculpas por mi ingles, no es muy bueno. Yes thank you, i´m testing vmix32bits (19.0.0.37 version). I´m Streaming to youtube a looping? mp4 video whith a looping overlay video, a mov video (im testing because before of this, vmix crash when overlay a move files). Do you understand me? :)
Why do you use 32bits version? Your computer is not 64bits capable?
Can you indicate which CPU and graphics card you use?
MOV videos require a lot of power. If your computer is not powerful enough maybe that's why it crashes.
I suppose you have alpha channel (transparency) in this video, right?
Tell us about your computer power. Maybe we can find another way to do what you want...
I use te 32 bits version because my captured card, Avermedia LGP, only work with this version. laptop HP Envy DV6 Intel core i7 3630QM 2.40GHz Nvida GeForce GT 635M 6 RAM yes, have alpha channel
I'm not sure if this graphics card is powerful enough. I don't know. The computer is OK.
You can try to convert your MOV video to MP4. Replace transparency by a color (not used in video) like green screen. Then you can use chroma to do the overlay or luma key+fill.
Not sure it's possible for you, it depends on the video. Is it a complex video or just a moving logo or blinking thing?
Yes, thank you for you help. i think this is the problem, the mov files. its no dificult to me to convert in a mp4. I do with NewBlue TittlerPro, its a volleball players presentation: Name, position age, etc and 1 photo, its no dificult to me do it in chroma key or probably i´ll do a PNG file, with no movement and effects, but with the overlays looks better :)
I think with NewBlue TittlerPro you can use NDI which supports alpha channel. It's even easier if you have the good version.
And you can use transparency and overlay with PNG files.
You can also use vMix Title Designer and Datasource to design your team/players presentation. You will see an example in this video
Yes, thankyou, very complicated for me :). i´ll try with Adobe Premiere Pro as a NDI source
Problem solved. This only happens when I have not connected the avermedia LGP in the USB port
