Joined: 1/13/2010(UTC) Posts: 5,311  Location: Gold Coast, Australia Was thanked: 4711 time(s) in 1615 post(s)
 12 users thanked admin for this useful post.
DWAM on 3/25/2017(UTC), corporatejames on 3/25/2017(UTC), ON.tv Channels on 3/25/2017(UTC), stigaard on 3/25/2017(UTC), richardgatarski on 3/25/2017(UTC), sinc747 on 3/25/2017(UTC), vijay6672 on 3/25/2017(UTC), DYosua on 3/25/2017(UTC), ask on 3/25/2017(UTC), pba on 3/25/2017(UTC), RoboST on 3/27/2017(UTC), BETech on 3/31/2017(UTC)
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
Just taken delivery of the ASUS 15.6" ROG Strix GL502VM as per sapphire spec at https://www.vmix.com/pro...e-systems.aspx#sapphire. Desktop capture with Chrome (latest version on win10) is black/blank. Firefox desktop capture however works ok though. Anyone else had this problem?
castfeeder wrote:Just taken delivery of the ASUS 15.6" ROG Strix GL502VM as per sapphire spec at https://www.vmix.com/pro...e-systems.aspx#sapphire. Desktop capture with Chrome (latest version on win10) is black/blank. Firefox desktop capture however works ok though. Anyone else had this problem? No, but that's the classic result from the browser leveraging hardware accelerated video rendering. Search for the flag to disable that in chrome.
 2 users thanked mjgraves for this useful post.
Thanks MJ. I went to chrome settings and unchecked 'use hardware acceleration when available'. This fixed the problem!
Joined: 11/13/2015(UTC) Posts: 16 Location: Sydney NSW Australia
Found a slight bug in the activators using vMix 19.0.0.37
I'm using a Behringer CMD DV-1 MIDI Controller.
The InputBusAAudio activators don't seem to work at all - or at least I can't find what they are indicating; but they show always On. The InputBusBAudio activators seem to be following my Bus A toggles in the interface.
cheers, Jared
Thanks for the report, we'll get this fixed in the next update.
Martin vMix
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ miguelernesto
You'll need to provide more info... When does this happen? System Specs? etc.
Joined: 1/15/2017(UTC) Posts: 45 Location: Exeter, UK
Thanks: 17 times Was thanked: 1 time(s) in 1 post(s)
I get the following after updating - When I click on the dropdown menus e.g. the 'input' dropdown on new shortcut box the dropdown appears as a blank list in the bottom corner of the screen.
Any ideas?
I am seeing another issue with triggers since the update. I don't seem to be able to change a transition in to a transition out. Also when making a new trigger and selecting title/stop countdown the third dropdown only works with arrow up/down keys i.e. there is no dropdown at all
Sounds like a scaling issue in Windows rather than a bug in vMix. To fix this, check for the latest windows updates, display drivers and then go to Display Settings in Windows and make sure the text size / zoom setting matches across all monitors, (preferably 100%)
admin wrote:Sounds like a scaling issue in Windows rather than a bug in vMix. To fix this, check for the latest windows updates, display drivers and then go to Display Settings in Windows and make sure the text size / zoom setting matches across all monitors, (preferably 100%) I solved this by changing the order of my monitors. I have three plugged into the graphics card on dvi (Windows saw this as screen 1), one on display port (screen 2) and one on hdmi (screen 3). I swapped the leads around to make the dvi rather than the HDMI my main monitor and rearranged in display options to be number 1 and set as primary display. After this all my dropdown issues disappeared. Can't think why this should cause this issue but thought I would share in case it was useful to anyone else. Alex
I get a "vMix has stopped working" message when clicking recording settings in vMix 19.0.0.38 Anyone else that has this happening?
 1 user thanked xaver for this useful post.
Thanks, so this only affects W10. That's fine because my production system runs W7 anyway.
Martin, with the new YT Live settings, would it be possible to select the channel you are streaming to, similar to the way channels are displayed with other stream destinations? Andrew
Thanks: 18 times Was thanked: 2 time(s) in 2 post(s)
ask wrote:Martin, with the new YT Live settings, would it be possible to select the channel you are streaming to, similar to the way channels are displayed with other stream destinations? Andrew When you select YT Live Live Stream Now, I see a Channel option (under Login).. I didn't try it, didn't even login.
I am missing the (Use hardware encoder) option in stream settings... in version 19.0.0.41
I am not sure if got moved somewhere else I can't find it
ask wrote:Martin, with the new YT Live settings, would it be possible to select the channel you are streaming to, similar to the way channels are displayed with other stream destinations? Andrew We thought about that, but due to the many steps needing to configure, preview and start an event needed to be done on the YouTube site itself it is probably quicker to just copy and paste the stream key for those streams to the existing YouTube Live dropdown option.
ngtech wrote:I am missing the (Use hardware encoder) option in stream settings... in version 19.0.0.41
Use hardware encoder will only appear when vMix is running on a NVIDIA graphics card. Can you confirm your system specs?
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
Random side note... I found an instance where some players were having issues playing streaming RTMP sources from vMix. I resolved it after reading online that the audio sample rate cannot be 48kHz in the FLV container in some players. I resolved the issue by adding "-ar 44100" to ffmpeg after copying the command line arguments to a command prompt.
