2 Pages12>
#1 Posted : Saturday, March 25, 2017 2:32:09 AM(UTC)
vMix 19 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
thanks 12 users thanked admin for this useful post.
DWAM on 3/25/2017(UTC), corporatejames on 3/25/2017(UTC), ON.tv Channels on 3/25/2017(UTC), stigaard on 3/25/2017(UTC), richardgatarski on 3/25/2017(UTC), sinc747 on 3/25/2017(UTC), vijay6672 on 3/25/2017(UTC), DYosua on 3/25/2017(UTC), ask on 3/25/2017(UTC), pba on 3/25/2017(UTC), RoboST on 3/27/2017(UTC), BETech on 3/31/2017(UTC)
castfeeder
#2 Posted : Sunday, March 26, 2017 6:10:02 PM(UTC)
castfeeder
Just taken delivery of the ASUS 15.6" ROG Strix GL502VM as per sapphire spec at https://www.vmix.com/pro...e-systems.aspx#sapphire. Desktop capture with Chrome (latest version on win10) is black/blank. Firefox desktop capture however works ok though. Anyone else had this problem?
mjgraves
#3 Posted : Tuesday, March 28, 2017 10:55:34 AM(UTC)
mjgraves
No, but that's the classic result from the browser leveraging hardware accelerated video rendering. Search for the flag to disable that in chrome.
thanks 2 users thanked mjgraves for this useful post.
castfeeder on 3/29/2017(UTC), sinc747 on 3/29/2017(UTC)
castfeeder
#4 Posted : Wednesday, March 29, 2017 5:46:47 PM(UTC)
castfeeder
Thanks MJ. I went to chrome settings and unchecked 'use hardware acceleration when available'. This fixed the problem!
jaredquinn
#5 Posted : Friday, March 31, 2017 12:33:19 AM(UTC)
jaredquinn
Found a slight bug in the activators using vMix 19.0.0.37
I'm using a Behringer CMD DV-1 MIDI Controller.
The InputBusAAudio activators don't seem to work at all - or at least I can't find what they are indicating; but they show always On.
The InputBusBAudio activators seem to be following my Bus A toggles in the interface.
cheers,
Jared
#6 Posted : Friday, March 31, 2017 3:35:33 AM(UTC)
Thanks for the report, we'll get this fixed in the next update.
#7 Posted : Saturday, April 1, 2017 10:21:16 AM(UTC)
@ miguelernesto
You'll need to provide more info...
When does this happen?
System Specs?
etc.
bitpod
#8 Posted : Sunday, April 2, 2017 6:48:32 AM(UTC)
bitpod
I get the following after updating - When I click on the dropdown menus e.g. the 'input' dropdown on new shortcut box the dropdown appears as a blank list in the bottom corner of the screen.
Any ideas?
bitpod
#9 Posted : Sunday, April 2, 2017 8:20:32 AM(UTC)
bitpod
I am seeing another issue with triggers since the update. I don't seem to be able to change a transition in to a transition out. Also when making a new trigger and selecting title/stop countdown the third dropdown only works with arrow up/down keys i.e. there is no dropdown at all
#10 Posted : Sunday, April 2, 2017 12:02:28 PM(UTC)
Sounds like a scaling issue in Windows rather than a bug in vMix.
To fix this, check for the latest windows updates, display drivers and then go to Display Settings in Windows
and make sure the text size / zoom setting matches across all monitors, (preferably 100%)
bitpod on 4/4/2017(UTC)
bitpod
#11 Posted : Tuesday, April 4, 2017 10:12:12 AM(UTC)
bitpod
I solved this by changing the order of my monitors. I have three plugged into the graphics card on dvi (Windows saw this as screen 1), one on display port (screen 2) and one on hdmi (screen 3).
I swapped the leads around to make the dvi rather than the HDMI my main monitor and rearranged in display options to be number 1 and set as primary display. After this all my dropdown issues disappeared.
Can't think why this should cause this issue but thought I would share in case it was useful to anyone else.
Alex
Mathijs
#12 Posted : Saturday, April 8, 2017 7:08:42 AM(UTC)
Mathijs
I get a "vMix has stopped working" message when clicking recording settings in vMix 19.0.0.38
Anyone else that has this happening?
xaver
#13 Posted : Saturday, April 8, 2017 7:15:10 AM(UTC)
xaver
see https://forums.vmix.com/....aspx?g=posts&t=9794
thanks 1 user thanked xaver for this useful post.
Mathijs on 4/8/2017(UTC)
Mathijs
#14 Posted : Saturday, April 8, 2017 7:27:34 AM(UTC)
Mathijs
Thanks, so this only affects W10. That's fine because my production system runs W7 anyway.
ask
#15 Posted : Wednesday, April 12, 2017 9:56:06 PM(UTC)
ask
Martin, with the new YT Live settings, would it be possible to select the channel you are streaming to, similar to the way channels are displayed with other stream destinations? Andrew
RoboST
#16 Posted : Thursday, April 13, 2017 1:53:32 PM(UTC)
RoboST
When you select YT Live Live Stream Now, I see a Channel option (under Login).. I didn't try it, didn't even login.
ngtech
#17 Posted : Thursday, April 13, 2017 4:59:16 PM(UTC)
ngtech
I am missing the (Use hardware encoder) option in stream settings... in version 19.0.0.41
I am not sure if got moved somewhere else I can't find it
#18 Posted : Thursday, April 13, 2017 9:54:53 PM(UTC)
We thought about that, but due to the many steps needing to configure, preview and start an event needed to be done on the YouTube site itself
it is probably quicker to just copy and paste the stream key for those streams to the existing YouTube Live dropdown option.
ask on 4/19/2017(UTC)
#19 Posted : Thursday, April 13, 2017 9:55:28 PM(UTC)
Use hardware encoder will only appear when vMix is running on a NVIDIA graphics card.
Can you confirm your system specs?
lbgaus
#20 Posted : Friday, April 14, 2017 12:43:01 AM(UTC)
lbgaus
Random side note... I found an instance where some players were having issues playing streaming RTMP sources from vMix. I resolved it after reading online that the audio sample rate cannot be 48kHz in the FLV container in some players. I resolved the issue by adding "-ar 44100" to ffmpeg after copying the command line arguments to a command prompt.
2 Pages12>
