How did you capture udp stream?
Hello
I am doing some tests for a broadcast, I use a server with a playout that generates a stream in udp, I use the following address udp: //239.1.1.1: 6506, but at the time of capturing this address in vmix I do not know how to be able To do it, could they help me?
Thanks for your reply
Hi Joel I guess this is Multicast UDP which vMix doesn't support What you can do is use VLC with NDI plugin. You ingest the multicast in VLC which converts it into a NDI stream that vMix can play. If you're interested in Multicast UDP support in vMix, please support this feature request https://forums.vmix.com/....aspx?g=posts&t=6869Hope this helps Guillaume
Thanks Guillaume
I will do what you say
