joelchavez
#1 Posted : Wednesday, March 29, 2017 11:31:26 AM(UTC)
joelchavez
Hello
I am doing some tests for a broadcast, I use a server with a playout that generates a stream in udp, I use the following address udp: //239.1.1.1: 6506, but at the time of capturing this address in vmix I do not know how to be able To do it, could they help me?
Thanks for your reply
#2 Posted : Wednesday, March 29, 2017 11:38:27 AM(UTC)
Was thanked: 794 time(s) in 589 post(s)
Hi Joel
I guess this is Multicast UDP which vMix doesn't support
What you can do is use VLC with NDI plugin. You ingest the multicast in VLC which converts it into a NDI stream that vMix can play.
If you're interested in Multicast UDP support in vMix, please support this feature request
https://forums.vmix.com/....aspx?g=posts&t=6869
Hope this helps
Guillaume
joelchavez on 3/29/2017(UTC)
joelchavez
#3 Posted : Wednesday, March 29, 2017 11:53:11 AM(UTC)
joelchavez
Thanks Guillaume
I will do what you say
