I have created some graphics using after effects that are renderd at 60FPS, once I play the graphic in Vmix the graphics is not playing smoothly at 60FPS. Help would be much appreciated.
Also, what is the best easy way to import/use graphics in vMix?
Couple of things to check:
Does the video play back in Windows Media Player ok? Is the output frame rate set to 60FPS in vMix settings? What graphics card do you have?
Thanks,
Martin vMix
Thanks for the reply.
Thank you, I just had to change the out put setting to 60PPS:)
Graphics card GTX 670
