Broadcasting27
#1 Posted : Sunday, February 24, 2013 2:45:52 AM(UTC)
Broadcasting27
I have created some graphics using after effects that are renderd at 60FPS, once I play the graphic in Vmix the graphics is not playing smoothly at 60FPS. Help would be much appreciated.
Also, what is the best easy way to import/use graphics in vMix?
#2 Posted : Sunday, February 24, 2013 10:32:18 AM(UTC)
Couple of things to check:
Does the video play back in Windows Media Player ok?
Is the output frame rate set to 60FPS in vMix settings?
What graphics card do you have?
Thanks,
Broadcasting27 on 2/24/2013(UTC)
Broadcasting27
#3 Posted : Sunday, February 24, 2013 7:22:16 PM(UTC)
Broadcasting27
Thanks for the reply.
Thank you, I just had to change the out put setting to 60PPS:)
Graphics card GTX 670
