Can't add 'photos' - slideshow to vMix get error
Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
When trying to add a source folder of photos I get the below error. I have tried 32 and 64 bit vMix 18 (latest) and vMix 19. Every single one gets the same error. What could the issue be?
Exception has been thrown by the target of an invocation.
AddNewInput Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Hi
this is a known bug with nVidia drivers on laptops.
Search "Attempted to read or write protected memory" in the forum you will find many topics about this issue and solutions for it.
Guillaume
Interesting.. Though I don't have an NVidia graphics card in the computer (running the Intel HD graphics 520) I tried the steps I found. Tried running only on the laptop itself with no external monitors - same issue Disabled FlipX entirely - same issue
I can open the program just fine, I simply can't add photos as a slideshow.
I've had no such problem doing that same thing. My vMix system has an older AMD Radeon card.
What size & format are the images?
Also, I never drag & drop a folder. I navigate into the folder and add all of its contents.
I have the same problem
I have Nvidia GPU and the driver is in the latest update already
Also, I'm in windows 10 Build 1703
It was fine when i run it, after update my windows to windows creator update, the problem occur
How to solve the problem?
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Update to the latest version of vMix to solve the problem.
