xaver
#1 Posted : Wednesday, March 22, 2017 1:38:36 PM(UTC)
xaver
Is there any way, to remember Key/Fill Input, if the Fill input was resetet?
I can Reset the input with shortcut (the Decklink Duo 2 goes black after about 4-5 days, so I have to reset the inputs)
But after the reset off the Fill, the input has no Key any more
How can I solve this problem?
xaver attached the following image(s):
#2 Posted : Wednesday, March 22, 2017 1:43:12 PM(UTC)
I never found a way to do this, but key fill inputs are saved with vMix presets so maybe if you can re-open the whole project preset, it might be quicker.
xaver
#3 Posted : Wednesday, March 22, 2017 5:03:45 PM(UTC)
xaver
I will try this, the next time, when the inputs are black
