ResetInput and Key/Fill Input
Is there any way, to remember Key/Fill Input, if the Fill input was resetet? I can Reset the input with shortcut (the Decklink Duo 2 goes black after about 4-5 days, so I have to reset the inputs) But after the reset off the Fill, the input has no Key any more How can I solve this problem? xaver attached the following image(s):  key-fill.jpg (39kb) downloaded 4 time(s).You cannot view/download attachments. Try to login or register.
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
I never found a way to do this, but key fill inputs are saved with vMix presets so maybe if you can re-open the whole project preset, it might be quicker.
I will try this, the next time, when the inputs are black
