tony marone
#1 Posted : Friday, January 28, 2011 2:26:19 AM(UTC)
tony marone
Hi Martin,
I really need to be able to rotate through cameras unattended. For instance cam1 for 15 seconds then cam2 for 15 seconds etc and then loop back to cam1 again. I know I asked you about this long ago, abouth the time you started the forum. Will this ever be a reality? I am an experienced Delphi programmer and capable of writing a small stand alone app thet could send keystrokes to vMix to accomplish this. I have done this successfully inserting keystrokes into Notepad but can't seem to insert keystrokes into vMix.
Thanks,
Tony
melody
#2 Posted : Friday, January 28, 2011 10:48:42 AM(UTC)
Rank: Guest
Groups: Guests
1 more vote.
tony marone
#3 Posted : Friday, January 28, 2011 11:34:34 AM(UTC)
tony marone
Update!
I have found a sure-fire way to grab the vMix window handle and now have a working autoswitch! It is pretty rudimentary right now but I will flesh it out with a config file so it might be useful to all. I will post a link to it when it is done and tested, if that's ok.
Tony
#4 Posted : Friday, January 28, 2011 11:04:57 PM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
vMix 2011 will have a new PlayList feature that can do what you want, or you can write your own program as you have discovered.
