Need autoswitch through cameras
Joined: 1/16/2010(UTC) Posts: 50  Location: usa Was thanked: 3 time(s) in 2 post(s)
Hi Martin,
I really need to be able to rotate through cameras unattended. For instance cam1 for 15 seconds then cam2 for 15 seconds etc and then loop back to cam1 again. I know I asked you about this long ago, abouth the time you started the forum. Will this ever be a reality? I am an experienced Delphi programmer and capable of writing a small stand alone app thet could send keystrokes to vMix to accomplish this. I have done this successfully inserting keystrokes into Notepad but can't seem to insert keystrokes into vMix.
Thanks,
Tony
Rank: Guest
Groups: Guests
Update!
I have found a sure-fire way to grab the vMix window handle and now have a working autoswitch! It is pretty rudimentary right now but I will flesh it out with a config file so it might be useful to all. I will post a link to it when it is done and tested, if that's ok.
Tony
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
vMix 2011 will have a new PlayList feature that can do what you want, or you can write your own program as you have discovered.
