Joined: 10/21/2016(UTC) Posts: 34   Location: Italy - Aosta Valley Thanks: 26 times Was thanked: 2 time(s) in 2 post(s)
Hello, I wanted to share with you this score Title volley. We may forward to sharing the Our and your Experiments to increase to the odds of graphic Vmix score. Mount Xaml + Green Volleyball With With Vmix designers Titles ... Good fun!File Attachment(s):  score_volley.xaml (5kb) downloaded 25 time(s).Matou attached the following image(s):  volleyball green.jpg (140kb) downloaded 17 time(s). Screensh_volley.jpg (60kb) downloaded 17 time(s).You cannot view/download attachments. Try to login or register.
Why do you use green background?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
The source does not specify a green background as such but is trying to load a green image as background which is indeed useless not only due to the fact it is not provided in the download. I imagine the green background is also including the colored backgrounds (blue, red , ...) for the data to be displayed over
tip: create those colored backgrounds on a transparent image or as smaller images to load , title editor creates the title with a transparent background as is
Hi, if you do not use the green but leave the Transparency creates a white background and the characters (white) become transparent.
Do not load any background image in Title Designer
create your scoreboard graphics in 1920x1080, PNG with alpha transparency, load it as an image with "Add Image" button
add your text fields
that's it
Thanks, I understood ! ;-) Here png format!File Attachment(s):  score_volley png.xaml (5kb) downloaded 11 time(s).Matou attached the following image(s):  volleyball png.jpg (140kb) downloaded 11 time(s).You cannot view/download attachments. Try to login or register.
That is not a .png file !
rename it in * .png filesFile Attachment(s):  Volleyball_png .zip (12kb) downloaded 17 time(s).You cannot view/download attachments. Try to login or register.
The first time you post something new, you have to understand the mechanisms of the forum. Here, finally, the 2 files to upload, the next post will be simpler!File Attachment(s):  score_volley png.xaml (5kb) downloaded 12 time(s). Volleyball_png .zip (12kb) downloaded 22 time(s).You cannot view/download attachments. Try to login or register.
It doesn't work this way. File properties are dependent on file formats. Alpha transparency can only be worked with if YOU save your file correctly.
Your zip file is corrupted
Would be simpler to just put the 2 files in 1 zip file instead of having to rename files and confuse people
DWAM wrote:Your zip file is corrupted no, he is telling to download it and rename the extension from zip to png :-(
Personally i prefer to have the squares programmed in the code instead of a separate image to load Much easier to match everything when designing (in blend) and not have to keep track of images but that's just me ;-)
here you go Handles attachments  score_volley_noimage.xaml (7kb) downloaded 23 time(s).You cannot view/download attachments. Try to login or register.
I agree with you - I have to understand in Adobe Photoshop how to create a "common ground" alpha.
Matou wrote:I agree with you - I have to understand in Adobe Photoshop how to create a "common ground" alpha. There is NO image to load involved here !
doggy wrote:Matou wrote:I agree with you - I have to understand in Adobe Photoshop how to create a "common ground" alpha. There is NO image to load involved here ! I understand That in your title - you need not need anything else. Now I spend a night of rest and try to figure out how to get your result (one file only). Thanks for your suggestions!
Before you understand how Doggy can do his magical trick I suggest you go step by step. ;o) The following is a good idea for step 1, I think Quote:I have to understand in Adobe Photoshop how to create a "common ground" alpha. Buona fortuna Guillaume
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I don't see reason to share this graphics like this. When I red the title I was thinking that someone made some controler and graphic for volleyball scoreboard...Too many posts for some .png file :) And graphics are quite simple and I don't like too many colors on them. There are details that are not well-done.. So, Matou if you are doing volleyball I would be glad to share my own graphics for it with you: See in video above how they look like But I welcome the good will to share
