2 Pages12>
Matou
#1 Posted : Monday, March 20, 2017 1:47:44 PM(UTC)
Matou
Italy
Hello, I wanted to share with you this score Title volley. We may forward to sharing the Our and your Experiments to increase to the odds of graphic Vmix score.
Mount Xaml + Green Volleyball With With Vmix designers Titles ...
Good fun!
File Attachment(s):
score_volley.xaml (5kb) downloaded 25 time(s).
Matou attached the following image(s):
volleyball green.jpg (140kb) downloaded 17 time(s).
#2 Posted : Monday, March 20, 2017 2:04:15 PM(UTC)
Why do you use green background?
#3 Posted : Monday, March 20, 2017 2:11:30 PM(UTC)
The source does not specify a green background as such but is trying to load a green image as background which is indeed useless not only due to the fact it is not provided in the download.
I imagine the green background is also including the colored backgrounds (blue, red , ...) for the data to be displayed over
tip: create those colored backgrounds on a transparent image or as smaller images to load , title editor creates the title with a transparent background as is
Matou on 3/20/2017(UTC)
Matou
#4 Posted : Monday, March 20, 2017 2:29:33 PM(UTC)
Matou
Italy
Hi, if you do not use the green but leave the Transparency creates a white background and the characters (white) become transparent.
#5 Posted : Monday, March 20, 2017 2:41:17 PM(UTC)
Do not load any background image in Title Designer
create your scoreboard graphics in 1920x1080, PNG with alpha transparency, load it as an image with "Add Image" button
add your text fields
that's it
Matou
#6 Posted : Monday, March 20, 2017 3:22:52 PM(UTC)
Matou
Italy
Thanks, I understood ! ;-)
Here png format!
File Attachment(s):
score_volley png.xaml (5kb) downloaded 11 time(s).
volleyball png.jpg (140kb) downloaded 11 time(s).
#7 Posted : Monday, March 20, 2017 3:37:42 PM(UTC)
That is not a .png file !
Matou
#8 Posted : Monday, March 20, 2017 3:56:05 PM(UTC)
Matou
Italy
rename it in * .png files
File Attachment(s):
Volleyball_png .zip (12kb) downloaded 17 time(s).
Matou
#9 Posted : Monday, March 20, 2017 4:00:01 PM(UTC)
Matou
Italy
The first time you post something new, you have to understand the mechanisms of the forum. Here, finally, the 2 files to upload, the next post will be simpler!
File Attachment(s):
score_volley png.xaml (5kb) downloaded 12 time(s).
Volleyball_png .zip (12kb) downloaded 22 time(s).
#10 Posted : Monday, March 20, 2017 4:01:58 PM(UTC)
It doesn't work this way. File properties are dependent on file formats.
Alpha transparency can only be worked with if YOU save your file correctly.
#11 Posted : Monday, March 20, 2017 4:03:33 PM(UTC)
Your zip file is corrupted
#12 Posted : Monday, March 20, 2017 4:05:09 PM(UTC)
Would be simpler to just put the 2 files in 1 zip file instead of having to rename files and confuse people
#13 Posted : Monday, March 20, 2017 4:06:23 PM(UTC)
no, he is telling to download it and rename the extension from zip to png :-(
#14 Posted : Monday, March 20, 2017 4:09:26 PM(UTC)
Personally i prefer to have the squares programmed in the code instead of a separate image to load
Much easier to match everything when designing (in blend) and not have to keep track of images but that's just me ;-)
#15 Posted : Monday, March 20, 2017 4:25:54 PM(UTC)
here you go
File Attachment(s):
score_volley_noimage.xaml (7kb) downloaded 23 time(s).
Matou
#16 Posted : Monday, March 20, 2017 4:51:01 PM(UTC)
Matou
Italy
doggy wrote:
here you go
I agree with you - I have to understand in Adobe Photoshop how to create a "common ground" alpha.
#17 Posted : Monday, March 20, 2017 5:00:24 PM(UTC)
Matou wrote:
doggy wrote:
here you go
There is NO image to load involved here !
Matou
#18 Posted : Monday, March 20, 2017 5:18:55 PM(UTC)
Matou
Italy
doggy wrote:
Matou wrote:
doggy wrote:
here you go
I understand That in your title - you need not need anything else.
Now I spend a night of rest and try to figure out how to get your result (one file only). Thanks for your suggestions!
#19 Posted : Monday, March 20, 2017 7:35:13 PM(UTC)
Before you understand how Doggy can do his magical trick I suggest you go step by step. ;o)
The following is a good idea for step 1, I think
Buona fortuna
Guillaume
Matou on 3/21/2017(UTC)
Siroki
#20 Posted : Tuesday, March 21, 2017 5:50:39 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
I don't see reason to share this graphics like this. When I red the title I was thinking that someone made some controler and graphic for volleyball scoreboard...Too many posts for some .png file :) And graphics are quite simple and I don't like too many colors on them. There are details that are not well-done..
So, Matou if you are doing volleyball I would be glad to share my own graphics for it with you:
See in video above how they look like
But I welcome the good will to share
2 Pages12>
