Murchik
#1 Posted : Saturday, March 18, 2017 8:06:13 PM(UTC)
Murchik
Ukraine
Hello. I for one of the projects use 3 cameras, each of which color key and with the imposition of backgrounds and scenery. How do I record them after all the processing with the multicorder ??? Is it even possible at all ??? Very necessary!
Thank you so much
#2 Posted : Saturday, March 18, 2017 8:19:25 PM(UTC)
@ Murchik
AFAIK, the Muticorder only records the source Video and Audio as it is received as an Input. Any effects processed through vMix can only be recorded as per the Streaming/Recording settings.
Murchik
#3 Posted : Saturday, March 18, 2017 8:26:41 PM(UTC)
Murchik
Ukraine
IceStream wrote:
@ Murchik
Can there be a possibility to simulate physical inputs from internal ??? I need to record 3 chambers separately after the batch and effects.
One more thing - in the future it is predicted that the Muticorder would remember the recording path in the project as in the master record ?? It's very inconvenient if I have 21 projects each time to specify the Muticorder path to write to the disk.
#4 Posted : Saturday, March 18, 2017 9:07:50 PM(UTC)
@ Murchik
Without knowing too much about your specific requirements and/or resources, I would possibly suggest vMix Replay as a possible solution (although I cannot confirm if a colour Key is processed pre-recording or not) although it should be noted, the recording is a single file and cannot be easily accessed outside of vMix.
Another possible solution, which probably doesn't meet your requirements, is to make a single recording of the "MultiView" 4 screen option of "Fullscreen" Output, such that your cameras with effects each occupy one of the display screens (Preview/Program//Input 1/Input 2).
Neither one is really what you want, but without using multiple computers and instances of vMix and/or external recorders I'm not sure you can get what you are currently seeking.
Murchik
#5 Posted : Saturday, March 18, 2017 9:25:06 PM(UTC)
Murchik
Ukraine
IceStream wrote:
@ Murchik
I can solve the problem but not in a very convenient way, because I will have to issue 2 outputs on one camera and wield them on the physical inputs of the boards (I have 2 DeckLink Duo 2) + boards to write down separately the master, but this is sooo inconvenient because it requires re-mixing ... and I need ready scenes for each camera to write down In full HD format and give it to the customer for further editing.In Adobe After Effects it turned out all the same thing, then it's harder then to write down right away.
But on the second question than please ??
One more thing - in the future it is predicted that the Muticorder would remember the recording path in the project as in the master record ?? It's very inconvenient if I have 21 projects each time to specify the Muticorder path to write to the disk. - ????
#6 Posted : Sunday, March 19, 2017 3:55:48 AM(UTC)
Hi Murchik
I can think of a solution but it would require 2 vMix and NDI recording with ISORecorder
vMix1 :
- inputs cam 1 & 2
- color keying and compositing for cam 1 & 2
- composited cam 1 goes to NDI program out for vMix2 AND NDI ISO Recorder
- composited cam 2 goes to NDI external2 out for vMix2 AND NDI ISO Recorder
vMix2 :
- inputs cam 3
- color keying and compositing for cam 3
- composited cam 3 goes to NDI external2 out for NDI ISO Recorder
- inputs composited cams 1 & 2 from NDI
> You can switch composited cams for streaming/recording
> You get all composited cams recorded individually
Maybe not what you expected, but as Ice said, with one single instance of vMix you can't do it
Guillaume
PS : it's also possible to record vMix1 PGM directly in vMix. This would save up 1 ISO recording so it only requires free version of NDI Recorder (2 simultaneous records)
Similar Topics
Multicorder suddenly created thousands of files??? (General Discussion)
by ben1000 10/30/2026 12:26:16 AM(UTC)
Record incoming SDI timecode (RP188) from DeckLink inputs in MultiCorder and Record (Feature Requests)
by Andrea Angeli 10/23/2026 7:49:20 AM(UTC)
Timecode info on Multicorder (Feature Requests)
by Gerard 7/10/2026 9:03:03 AM(UTC)
Production Clock to have Multicorder option status for recording (Feature Requests)
by Paul CVP 5/28/2026 10:28:41 AM(UTC)
Record Zoom with Multicorder (General Discussion)
by stranddoctor 2/19/2026 3:11:59 AM(UTC)
Start recording/multicorder when start stream (Feature Requests)
by PeteFitz-Nova 1/15/2026 12:15:04 PM(UTC)
vMix-Multicorder: Can vMix receive and save a TimeCode-Signal? (General Discussion)
by FelixBonn 11/24/2025 11:04:24 PM(UTC)
PreBuffer for Multicorder/Recording (Feature Requests)
by Machtl 11/6/2025 7:17:59 PM(UTC)
MultiCorder – Record Audio Inputs & Choose Audio per Camera It (Feature Requests)
by Charles P 10/1/2025 7:22:33 PM(UTC)
Powerpoint x talking head -> 3 separate multicorder files (General Discussion)
by sdspieg 9/22/2025 2:08:19 PM(UTC)
record input + a bus on multicorder (Feature Requests)
by Ittaidv 9/15/2025 12:29:48 AM(UTC)
Multicorder multiple audio channels (Feature Requests)
by Jp12687 8/12/2025 9:23:44 AM(UTC)
Request to Review MP4 Codec in vMix Multicorder – Compatibility Issues with DaVinci Resolve 20 (General Discussion)
by Sergio Cardoso 7/26/2025 8:07:56 AM(UTC)
MultiCorder folder in the API (Feature Requests)
by Aki 7/9/2025 6:45:14 PM(UTC)
MultiCorder - What determines which inputs are available? (General Discussion)
by knbPixels 6/4/2025 1:14:15 AM(UTC)
Recording vMix multicorder to QNAP NAS (General Discussion)
by podshopstudios 6/2/2025 5:42:02 PM(UTC)
Timecode to Multicorder, Recorder and Cameras Hack (General Discussion)
by nowski 3/30/2025 12:15:01 AM(UTC)
External Timecode for multicorder (Feature Requests)
by adell 3/27/2025 4:18:29 AM(UTC)
Multicorder Audio L/R mono (General Discussion)
by nicksimoneau 2/28/2025 1:25:11 AM(UTC)
Color change on Output vs. Camerainput when recording in MultiCorder (General Discussion)
by toerstveiten 11/6/2024 6:49:31 PM(UTC)
Audio recording in Native NDI/MultiCorder (.mov) (NDI)
by boris9831 10/21/2024 9:12:05 AM(UTC)
Multicorder Random no audio recording (General Discussion)
by freedomW 9/30/2024 12:52:05 PM(UTC)
Add Multicorder to Production Clock (Feature Requests)
by WaltG12 9/21/2024 7:01:24 AM(UTC)
ISO recording of MultiCorder (General Discussion)
by Beam-A-Live 8/19/2024 4:33:51 PM(UTC)
Custom multichannel audio bus selections for recording/multicorder (Feature Requests)
by WaltG12 5/3/2024 5:42:43 PM(UTC)
Recording ASIO audio with Multicorder - A workaround (Showcase)
by wthblondie 12/31/2023 12:50:09 AM(UTC)
Blinking MultiCorder / Record button (Feature Requests)
by jet 12/19/2023 7:12:17 AM(UTC)
Unable to record zoom inputs in Multicorder (Beta Discussion)
by Nigel.Mercer 11/20/2023 6:40:03 PM(UTC)
Multicorder and PGR record..sometimes with variable fps (General Discussion)
by openaspace 11/18/2023 6:38:40 AM(UTC)
New MultiCorder operational suggestion (Feature Requests)
by tvpRich 10/12/2023 8:27:33 AM(UTC)
