Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
Hello. I for one of the projects use 3 cameras, each of which color key and with the imposition of backgrounds and scenery. How do I record them after all the processing with the multicorder ??? Is it even possible at all ??? Very necessary! Thank you so much
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ Murchik
AFAIK, the Muticorder only records the source Video and Audio as it is received as an Input. Any effects processed through vMix can only be recorded as per the Streaming/Recording settings.
IceStream wrote:@ Murchik
Ice Can there be a possibility to simulate physical inputs from internal ??? I need to record 3 chambers separately after the batch and effects. One more thing - in the future it is predicted that the Muticorder would remember the recording path in the project as in the master record ?? It's very inconvenient if I have 21 projects each time to specify the Muticorder path to write to the disk.
@ Murchik
Without knowing too much about your specific requirements and/or resources, I would possibly suggest vMix Replay as a possible solution (although I cannot confirm if a colour Key is processed pre-recording or not) although it should be noted, the recording is a single file and cannot be easily accessed outside of vMix. Another possible solution, which probably doesn't meet your requirements, is to make a single recording of the "MultiView" 4 screen option of "Fullscreen" Output, such that your cameras with effects each occupy one of the display screens (Preview/Program//Input 1/Input 2). Neither one is really what you want, but without using multiple computers and instances of vMix and/or external recorders I'm not sure you can get what you are currently seeking.
Ice I can solve the problem but not in a very convenient way, because I will have to issue 2 outputs on one camera and wield them on the physical inputs of the boards (I have 2 DeckLink Duo 2) + boards to write down separately the master, but this is sooo inconvenient because it requires re-mixing ... and I need ready scenes for each camera to write down In full HD format and give it to the customer for further editing.In Adobe After Effects it turned out all the same thing, then it's harder then to write down right away. But on the second question than please ?? One more thing - in the future it is predicted that the Muticorder would remember the recording path in the project as in the master record ?? It's very inconvenient if I have 21 projects each time to specify the Muticorder path to write to the disk. - ????
Hi Murchik
I can think of a solution but it would require 2 vMix and NDI recording with ISORecorder
vMix1 : - inputs cam 1 & 2 - color keying and compositing for cam 1 & 2 - composited cam 1 goes to NDI program out for vMix2 AND NDI ISO Recorder - composited cam 2 goes to NDI external2 out for vMix2 AND NDI ISO Recorder
vMix2 : - inputs cam 3 - color keying and compositing for cam 3 - composited cam 3 goes to NDI external2 out for NDI ISO Recorder - inputs composited cams 1 & 2 from NDI
> You can switch composited cams for streaming/recording > You get all composited cams recorded individually
Maybe not what you expected, but as Ice said, with one single instance of vMix you can't do it
Guillaume
PS : it's also possible to record vMix1 PGM directly in vMix. This would save up 1 ISO recording so it only requires free version of NDI Recorder (2 simultaneous records)
