66 Pages«<1415161718>»
elgarf
#301 Posted : Saturday, March 18, 2017 11:56:01 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Bandit62, I'll add On Top tick in the next update.
As for "little dots where the are located", looks like I should make them images, not font glyphs.
#302 Posted : Saturday, March 18, 2017 12:27:45 PM(UTC)
I also am at a loss here, as how to update a list: For example, I had a list of 8 players, but then the list was updated to 10 players...How do I update my list in UTC, or do I always have to make a new one each time it changes..How do I modify my list....
It depends... How did you build the list first?
You have at least 2 options:
- first you can simply use List Widget's "Add List Item"
- or you can use a CSV file to load items into your List
I did a small tutorial for using Lists in UTC. I show these 2 options in the video (and you will see the buttons which don't show for you)
https://forums.vmix.com/...ts&m=34858#post34858
Siroki
#303 Posted : Sunday, March 19, 2017 5:47:54 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
Bandit62 wrote:
Siroki wrote:
Bandit62 wrote:
Hi guys...been testing the program, and so far it works great...One problem I have, is that when using it on a single monitor, every time I use vMix, it goes to the back, and I have to use the taskbar to bring it to front again...is there a way to lock it to stay infront at all times.
Thanks for a very useful piece of software...
Why do you send it on back. I setup everything on UTC and minimize vMix and control everything in UTC. SO its fullscreen all the time
That is what I had to do, and place it next to vMix, but I wanted to place it on top of vMix where the audio meters are located...nevertheless, I found a way to get it to work that is acceptable.....Thanks..
I also am at a loss here, as how to update a list: For example, I had a list of 8 players, but then the list was updated to 10 players...How do I update my list in UTC, or do I always have to make a new one each time it changes..How do I modify my list....And another issue I have...I loaded UTC on a PC that is running windows 7, and the buttons do not show...I get little dots where the are located..( lock, copy, Properties and close)....they are all small square dots....
Sorry you are right, I didn't know you need audio meteres. I don't need them because its controlled with ATEM and there is audio master who deals with audio on mixer.
I change lists of players all the time. Just save in notepad a .txt file, go into UTC load that file and there are new names. When there is a second game and second players, make another .txt file with other names or changes and load it again and it worked...
I had problems with buttons also and I just put right font on windows FONTS folder and its fine after that. I will send it to you in PM
best regards
#304 Posted : Sunday, March 19, 2017 6:24:36 AM(UTC)
You can download the missing font "Segoe UI Symbol" for vMix UTC icons in Windows 7 here:
http://www.myfontfree.co...ontfreecom126f132800.htm
@Elgarf
Maybe you can add this download in first post?
elgarf
#305 Posted : Sunday, March 19, 2017 7:09:34 AM(UTC)
elgarf
Russian Federation
@DWAM, I better change font to free alternative.
BTW, I want update UTC today with Clock (Scheduler) widget and new icons, which don't depend on Segoe UI Symbol font.
thanks 1 user thanked elgarf for this useful post.
DWAM on 3/19/2017(UTC)
Bandit62
#306 Posted : Sunday, March 19, 2017 7:56:42 AM(UTC)
Rank: Guest
Groups: Guests
Or you can just add the link for the font, and that would be ok...it worked for me....now I am happy
elgarf
#307 Posted : Tuesday, March 21, 2017 12:00:08 AM(UTC)
elgarf
Russian Federation
Btw, I replaced icons)
First post
elgarf
#308 Posted : Thursday, March 23, 2017 9:32:21 AM(UTC)
elgarf
Russian Federation
I made small UI changes, such of:
1) now widget properties should remember window width/height for each widget.
2) scroll through mouse wheel works on all area of properties window (very handful).
3) there is now tooltip with active hotkeys/exec links on each widget, you don't need open properties if you want just look at execLinks.
4) ability to collapse commands in script, so they take less space.
5) design changes.
First post
DWAM on 3/23/2017(UTC)
#309 Posted : Thursday, March 23, 2017 9:48:22 AM(UTC)
Nice! Thanks Elgarf
JAIRODJ
#310 Posted : Thursday, March 23, 2017 12:13:06 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Excellent work thank you
vadim_d
#311 Posted : Friday, March 24, 2017 2:13:52 AM(UTC)
vadim_d
in last version not work - external data , copy widget for button :(
elgarf
#312 Posted : Friday, March 24, 2017 2:21:43 AM(UTC)
elgarf
Russian Federation
@vadim_d, must be fixed now.
Bandit62
#313 Posted : Friday, March 24, 2017 11:26:00 AM(UTC)
Rank: Guest
Groups: Guests
I have a silly question.....will the app work with other programs such as Atem, wirecast and such like....
elgarf
#314 Posted : Friday, March 24, 2017 11:27:35 AM(UTC)
elgarf
Russian Federation
@Bandit62, nope, it depends on vMix web API =(
Siroki
#315 Posted : Tuesday, March 28, 2017 7:27:35 AM(UTC)
Siroki
elgarf wrote:
@Siroki, I think I can make TextFile Data Provider for external data widget, just a bit later.
Whats your idea on this?
Are you able to do something?
thx
#316 Posted : Tuesday, March 28, 2017 11:45:16 AM(UTC)
Hi Elgarf
First I found an issue with last version: the "Copy Widget" function on Buttons makes UTC crash as soon as a script is created in the button.
Then I added 10 new commands in functions.xml. Most of them are very basic but some others might require you to add the active state concept.
Here they are :
- CutDirect
- MultiViewOverlay
- MoveMultiViewOverlay
- SelectIndex for VirtualSets
- SelectIndex for Lists & Photos
- SelectPlayList
- StartPlayList
- StopPlayList
- PreviousPlayListEntry
- NextPlayListEntry
I also tried to reorganize functions.xml which was becoming messy. I added sort of categories for commands to make them easier to find (both in the xml file and the dropdown menu). See attached screencap.
Keep whatever you like. Throw it away if you don't ! ;o)
Bien à toi
Guillaume
File Attachment(s):
Functions.xml.txt (22kb) downloaded 18 time(s).
DWAM attached the following image(s):
#317 Posted : Tuesday, March 28, 2017 11:50:54 AM(UTC)
XML file uploading is not allowed in the forum. Make sure to rename functions.xml.txt to functions.xml if you use it.
elgarf
#318 Posted : Tuesday, March 28, 2017 12:09:53 PM(UTC)
elgarf
Russian Federation
@DWAM, I made groups a bit better. Can you send me *.vmc file where you get crash on copying button?
#319 Posted : Tuesday, March 28, 2017 12:16:37 PM(UTC)
I guess you can reproduce the issue easily :
create a button, as soon as you insert a script in it, then the copy widget makes it crash
I just did it with a blank project, inserted a timer with "start" as link for execute, did a Button with execLink to "start" and then tried to copy... crash...
elgarf
#320 Posted : Tuesday, March 28, 2017 1:00:58 PM(UTC)
elgarf
Russian Federation
Hmmmmm... It's not crash for me. Try this version enable logging, try copy button and send me log if button will not copy.
Guest (13)
