Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
Hi Guys I have a cctv system which has an ip address and i can see it on the network . I'd love to be able to bring in the cameras. They are not ip based . So I could switch it on the cctv system and choose which one I want. Has anybody done this or could recommend the best way to do it? Desktop capture or some better way? I have reserved it's ip address in my router so I know that will not change. Thanks Cormac
Two options - if the cameras themselves are IP, you may be able to get them to produce a separate, second stream to the one you are recording on the existing DVR/NVR - most cameras allow two.
If the cameras are anything but IP (analogue, TVI etc) then you may well still find that the DVR has a streaming URL for each camera - as an RTSP stream. These are normally not well documented and you may need a little googling or forum hunting to find the exact URL. The same thing is often used for a remote 'spot monitor' (to give you a google headstart).
Good luck - report back if you get it working!
