fabio_ps
#1 Posted : Thursday, January 27, 2011 3:15:30 PM(UTC)
fabio_ps
it is possible to change camera using chroma?
When i try this, the background image blinks in full screen. (Overlay -> Overlay)
Thanks.
#2 Posted : Thursday, January 27, 2011 10:13:42 PM(UTC)
Yes, it should work fine.
Do you mean the fade effect when changing the overlay? Would you like an option to Cut instead of Fade when changing the overlay?
fabio_ps
#3 Posted : Thursday, February 10, 2011 5:21:53 PM(UTC)
fabio_ps
Yes. Exactly. Is it possible implement a option to "cut on overlay" on the next realese?
#4 Posted : Friday, February 11, 2011 6:09:22 AM(UTC)
The next Beta will include the ability to specify a transition effect on each overlay.
This includes the "Cut" effect which swaps instantly.
