it is possible to change camera using chroma?
When i try this, the background image blinks in full screen. (Overlay -> Overlay)
Thanks.
Joined: 1/13/2010(UTC) Posts: 5,337  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
Yes, it should work fine.
Do you mean the fade effect when changing the overlay? Would you like an option to Cut instead of Fade when changing the overlay?
Yes. Exactly. Is it possible implement a option to "cut on overlay" on the next realese?
The next Beta will include the ability to specify a transition effect on each overlay. This includes the "Cut" effect which swaps instantly.
