jladnil
#1 Posted : Wednesday, March 8, 2017 4:54:32 AM(UTC)
jladnil
I am running Beta 19.0.0.33 Version in Title Editor I cannot set the duration. When i set the duration and click ok it becomes 00:00:00 again. Is it a Bug? or am I missing something.
#2 Posted : Wednesday, March 8, 2017 5:25:13 AM(UTC)
Hi
durations are to be set in vMix not in Title Designer where you only define a field for duration with position, style, etc... When done, load your xaml in vMix project and use Title Editor to set the timer to this field.
jladnil
#3 Posted : Wednesday, March 8, 2017 5:26:53 AM(UTC)
jladnil
CAN U PLEASE TELL ME HOW TO SET DURATION IN VMIX FOR TITLE
#4 Posted : Wednesday, March 8, 2017 5:34:52 AM(UTC)
Sorry my previous answer was wrong, I mixed up Title Designer and Title Editor. Not well awaked!
Load a title, choose the field you want for timer and indicate a duration and press ok. By default it will countdown.
Now in vMix your timer should run, simply overlay your title to see it
Check this for all options : http://www.vmix.com/help19/Title.html
jladnil
#5 Posted : Wednesday, March 8, 2017 5:42:50 AM(UTC)
jladnil
I think you are talking about "Countdown Timer". Well i need to set Duration (Ticker duration) for my title so it fades off after 5sec and fades back in
stigaard
#6 Posted : Wednesday, March 8, 2017 7:19:16 AM(UTC)
stigaard
Denmark
Ticker duration is a feature to make the text content scroll from left to right (or opposite direction).
I think what you need to do is to set up a trigger. The trigger will be a "OnOverlayIn" trigger, and will have a delay of 5000 ms, and will trigger "OnOverlay1Out" (if you use the title on Overlay channel 1), which fades out the title.
See the image below
thanks 1 user thanked stigaard for this useful post.
jladnil on 3/8/2017(UTC)
jladnil
#7 Posted : Wednesday, March 8, 2017 9:33:38 AM(UTC)
jladnil
Thank You It does fade out now but how do I make it come back again automatically?
stigaard
#8 Posted : Wednesday, March 8, 2017 9:42:44 AM(UTC)
stigaard
Denmark
Do you want to rotate between 2 or more lower third titles or likewise?
Then I would recommend you to take a look at the Playlist feature. The playlist feature can handle looping between inputs (video and also titles) on different overlay channels and much more.
jladnil on 3/9/2017(UTC)
jladnil
#9 Posted : Thursday, March 9, 2017 1:13:45 PM(UTC)
jladnil
Guys i am stuck in title designer somehow i cannot change the height of text property. I can adjust the width not the height whenever I input some value it goes back to 74. See image below [img][/img]
jladnil attached the following image(s):
#10 Posted : Thursday, March 9, 2017 1:55:54 PM(UTC)
Change fontsize
jladnil
#11 Posted : Thursday, March 9, 2017 1:58:22 PM(UTC)
jladnil
That only makes font bigger
#12 Posted : Thursday, March 9, 2017 2:34:08 PM(UTC)
You asked "change the height of text property."
box height is related to fontsize, if text is longer than width of box it will also change height (add line)
Guest (9)
