jladnil
#1 Posted : Wednesday, March 8, 2017 4:54:32 AM(UTC)
jladnil
I am running Beta 19.0.0.33 Version in Title Editor I cannot set the duration. When i set the duration and click ok it becomes 00:00:00 again. Is it a Bug? or am I missing something.
#2 Posted : Wednesday, March 8, 2017 5:25:13 AM(UTC)
Hi
durations are to be set in vMix not in Title Designer where you only define a field for duration with position, style, etc... When done, load your xaml in vMix project and use Title Editor to set the timer to this field.
jladnil
#3 Posted : Wednesday, March 8, 2017 5:26:53 AM(UTC)
jladnil
CAN U PLEASE TELL ME HOW TO SET DURATION IN VMIX FOR TITLE
#4 Posted : Wednesday, March 8, 2017 5:34:52 AM(UTC)
Sorry my previous answer was wrong, I mixed up Title Designer and Title Editor. Not well awaked!
Load a title, choose the field you want for timer and indicate a duration and press ok. By default it will countdown.
Now in vMix your timer should run, simply overlay your title to see it
Check this for all options : http://www.vmix.com/help19/Title.html
jladnil
#5 Posted : Wednesday, March 8, 2017 5:42:50 AM(UTC)
jladnil
I think you are talking about "Countdown Timer". Well i need to set Duration (Ticker duration) for my title so it fades off after 5sec and fades back in
stigaard
#6 Posted : Wednesday, March 8, 2017 7:19:16 AM(UTC)
stigaard
Denmark
Ticker duration is a feature to make the text content scroll from left to right (or opposite direction).
I think what you need to do is to set up a trigger. The trigger will be a "OnOverlayIn" trigger, and will have a delay of 5000 ms, and will trigger "OnOverlay1Out" (if you use the title on Overlay channel 1), which fades out the title.
See the image below
thanks 1 user thanked stigaard for this useful post.
jladnil on 3/8/2017(UTC)
jladnil
#7 Posted : Wednesday, March 8, 2017 9:33:38 AM(UTC)
jladnil
Thank You It does fade out now but how do I make it come back again automatically?
stigaard
#8 Posted : Wednesday, March 8, 2017 9:42:44 AM(UTC)
stigaard
Denmark
Do you want to rotate between 2 or more lower third titles or likewise?
Then I would recommend you to take a look at the Playlist feature. The playlist feature can handle looping between inputs (video and also titles) on different overlay channels and much more.
jladnil on 3/9/2017(UTC)
jladnil
#9 Posted : Thursday, March 9, 2017 1:13:45 PM(UTC)
jladnil
Guys i am stuck in title designer somehow i cannot change the height of text property. I can adjust the width not the height whenever I input some value it goes back to 74. See image below [img][/img]
jladnil attached the following image(s):
#10 Posted : Thursday, March 9, 2017 1:55:54 PM(UTC)
Change fontsize
jladnil
#11 Posted : Thursday, March 9, 2017 1:58:22 PM(UTC)
jladnil
That only makes font bigger
#12 Posted : Thursday, March 9, 2017 2:34:08 PM(UTC)
You asked "change the height of text property."
box height is related to fontsize, if text is longer than width of box it will also change height (add line)
