madness
#1 Posted : Wednesday, March 2, 2016 12:57:48 PM(UTC)
madness
For those interested. This was asked for in the forums, so I thought I'd take a stab at sharing what I have done, but from scratch using mattes from google images.
I used these 3 sources...
I put these images in a folder, and imported this to vMix as a photos folder input and configured to loop and pushed play.
This gave me a test animated luma mask.
Next, I created an input for my background. In this case another photos folder with random birthday images.
Again, I looped this input and pressed play. This gives me an animated background.
Both of the previous inputs could be video sources if desired.
Finally, I created an input of my foreground video content.
In the settings of this input, I select the Color key tab, and then at the bottom, change the "Key/Fill Input" to the Luma Mask input.
The white from the luma mask allows the content to show, while the Black blocks the input.
Now, I can overlay this masked input over my background input, or select it as a multiview input for my background input.
Here is the result...
@sinc747, Tom, You should do this on Streaming Idiots!
thanks 1 user thanked madness for this useful post.
stigaard on 3/6/2017(UTC)
madness
#2 Posted : Monday, March 6, 2017 10:37:55 AM(UTC)
madness
The post above has one side effect when zooming, re-positioning the foreground image/video. The Luma Key mask is locked to the size of the image/video, and therefore moves/resizes with it.
In the following video, the mask is inverted, and applied to the background image video, allowing the foreground image/video (actually the background) to show through the background (truly the foreground).
Yes, Everything is flipped!
Background is the foreground
Foreground is the background
Black is white
White is black
I am soooo confused!
But the result is working!
Peter B
#3 Posted : Tuesday, March 7, 2017 7:49:06 PM(UTC)
Peter B
I was playing with animated mattes to make custom wipe patterns and masks, it worked but was a bit of a setup.
Having them integrated as transition presets using user made animated masks as a source would make it a lot easier. Similar to a stinger in implementation.
A powerful feature the key / fill input in colour key.
https://forums.vmix.com/....aspx?g=posts&t=6706
