Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Hi
Right now, 4 external output would be really useful for me - I'm running vMix 4K.
I can see even more being useful with vMix Call and NDI apps, like the telestrator, particularly for vMix Pro.
I've searched but I don't think this has been requested anywhere else - apologies if I have missed it!
G.
Joined: 4/14/2013(UTC) Posts: 264  Location: Australia Thanks: 35 times Was thanked: 38 time(s) in 36 post(s)
+1
Maybe some virtual externals that were also available as sources as a way to switch the input to a multiview box insert without having to setup virtual sources.
I remember these previous requests. Then a floating window with multiple cut busses for the external(s) and fullscreens for faster access and visual feedback. Possibly a bus to feed the multicorder when used as an iso recorder saving having to use more than one.
Some mixers have a user table that will switch another bus depending on whats on PGM -
PGM ... External bus priority
Cam1 ... Cam4 wide shot Cam2 ... Cam3 Cam3 ... Cam4 wide shot Cam4 ... Cam2 Replay . Cam1 Presenter
This means you will never record the PGM camera twice on an iso record, great for post fixups or switch the PGM camera to an in set screen causing feedback.
+1, more is always better :)
Joined: 5/24/2015(UTC) Posts: 370 Location:: Netherlands
Joined: 10/18/2015(UTC) Views messages in topic : 185 Location: Newcastle NSW Australia
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Joined: 9/9/2016(UTC) Posts: 23  Location: Fresh Start Church Thanks: 2 times Was thanked: 3 time(s) in 3 post(s)
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
Thanks: 3 times Was thanked: 5 time(s) in 4 post(s)
