imrwrk
#1 Posted : Saturday, March 4, 2017 4:57:36 PM(UTC)
imrwrk
Can you please add this feature if possible to stop recording after certain time? example stop recording the file when it reaches 1 hour 15 minutes and etc...
#2 Posted : Saturday, March 4, 2017 5:07:20 PM(UTC)
Highly likely possible with scripting
#3 Posted : Saturday, March 4, 2017 5:17:28 PM(UTC)
Hi
if you want you can do this very easily with vMixUTC
https://forums.vmix.com/....aspx?g=posts&t=6468
It takes 30 seconds to setup:
Create a Timer Widget, set it to 1h15 with "reverse" option to make it a countdown
Fill the "On Completion" field with a command name like "StopMyRec"
Now create a Button Widget and give it a name
Tick the "execute" box and write "StopMyRec" in the link field
Click the "script" + sign
Select "execlink" in the dropdown menu and select "StopRecording" in the function menu
If you click this button manually, vMix recording stops
Now start the countdown. When it reaches 0:00, the command "StopMyRec" is sent to auto execute the Button command.
Et voila!
Longer to write than to do! ;o)
Guillaume
gez737 on 5/3/2020(UTC)
imrwrk
#4 Posted : Saturday, March 4, 2017 6:52:12 PM(UTC)
imrwrk
Thanks DWAM. I will give it a try. but it will be nice to have that built in if possible.
gez737
#5 Posted : Sunday, May 3, 2020 7:07:14 PM(UTC)
gez737
Hi Guillaume,
Google searched 'Stop Recording in vMix' - and your guide popped up.
I played around with UTC a coupe of years ago, but have not been back on it, until now...
After a little trial and error - managed to work it out and it works beautifully.
I assume you can do the same for "Stop Stream"
Thanks again.
cheers
Gerry.
