Feature Requests
Stop Recording after certain amount of time
Can you please add this feature if possible to stop recording after certain time? example stop recording the file when it reaches 1 hour 15 minutes and etc...
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Highly likely possible with scripting
Hi if you want you can do this very easily with vMixUTC https://forums.vmix.com/....aspx?g=posts&t=6468It takes 30 seconds to setup: Create a Timer Widget, set it to 1h15 with "reverse" option to make it a countdown Fill the "On Completion" field with a command name like "StopMyRec" Now create a Button Widget and give it a name Tick the "execute" box and write "StopMyRec" in the link field Click the "script" + sign Select "execlink" in the dropdown menu and select "StopRecording" in the function menu If you click this button manually, vMix recording stops Now start the countdown. When it reaches 0:00, the command "StopMyRec" is sent to auto execute the Button command. Et voila! Longer to write than to do! ;o) Guillaume
Thanks DWAM. I will give it a try. but it will be nice to have that built in if possible.
Hi Guillaume,
Google searched 'Stop Recording in vMix' - and your guide popped up. I played around with UTC a coupe of years ago, but have not been back on it, until now...
After a little trial and error - managed to work it out and it works beautifully.
I assume you can do the same for "Stop Stream"
Thanks again.
cheers Gerry.
Feature Requests
