66 Pages«<1213141516>»
elgarf
#261 Posted: : Wednesday, February 8, 2017 1:50:34 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
Hi
I made small changes to path parsing for state depend/direct commands, so now SetMultiViewOverlay is state dependent command, also I added SetTextNative & SetImageNative commands, which works with index properties of texts/images/etc.
I'll upload new version later.
#262 Posted : Wednesday, February 8, 2017 2:54:38 PM(UTC)
Ok thanks
While we're in functions, I'am also working on adding:
SetOutputExternal2
SetOutputFullscreen2
So far it is not perfect but it works. Here's what I did:
Code:
<vMixFunctionReference>
    <Description>Set Output External2</Description>
    <Function>SetOutputExternal2</Function>
    <FormatString>Function=SetOutputExternal2&amp;Value={2}&amp;Input={0}</FormatString>
    <StringDescription>Type</StringDescription>
  </vMixFunctionReference>
My idea was to pick in the dropdown which input to use --> {0}. This is fine when Type is set to Input.
When Type is Output, Preview or Multiview it makes no sense but it works anyway... So I don't know what's best.
I tested two solutions
1 . create 2 separate functions
- the 1st one is for Output, Preview or Multiview ONLY with <FormatString>Function=SetOutputExternal2&amp;Value={2}</FormatString>
- the 2nd one is for Input ONLY. It could be called Set Input to Output External2 with <FormatString>Function=SetOutputExternal2&amp;Value={2}&amp;Input={0}</FormatString>
2 . stick to a single function for all use case but instead of picking the input in the dropdown, do :
<FormatString>Function=SetOutputExternal2&amp;Value={2}&amp;Input={1}</FormatString>
<IntDescription>Input Number</StringDescription>
where {2} can be Output, Preview, Multiview AND input and {1} is the input number
For this solution I think there are 2 cons:
- it is not presented in the logical order
- it is less "cool"
But you know better...
I'd like to implement these 2 new functions to extend vMix for a second operator to be able to make a 2nd switching for a beamer on external2 for example.
Also it is useful via NDI so that vMix UTC can select NDI source to monitor without affecting program.
elgarf
#263 Posted : Thursday, February 9, 2017 1:54:07 AM(UTC)
elgarf
Russian Federation
New version is ready.
Now commands can have predefined list of values in parameters, so you don't need to write overlay number manually - just select it from the list.
Added new <MIDI Device> widget, so you can map your ExecLinks to MIDI buttons.
First post
thanks 1 user thanked elgarf for this useful post.
Mari on 2/9/2017(UTC)
#264 Posted : Thursday, February 9, 2017 11:39:23 AM(UTC)
Hi Elgarf!
Thanks for this new version.
I think "State Dependent" feature doesn't work anymore... But new look (circle leds instead of squares) is OK.
Regarding this feature, is it "safe" to invert initial ActiveStateValue so that it's red when active and green when not active?
I thought you would have added SetMultiViewOverlay, SetTextNative & SetImageNative (and maybe SetOutputExternal2, SetOutputFullscreen2) in functions.xml. Did you change your mind or simply forgot?
Also I didn't find this. Maybe it's related to not updating functions.xml?
Bien à toi,
Guillaume
PS : If you forgot to update functions.xml, maybe you can just attach it here...
elgarf
#265 Posted : Thursday, February 9, 2017 11:41:54 AM(UTC)
elgarf
Russian Federation
Yep, I just forgot to update functions.xml =(
BTW, redownload, please, updated archive.
#266 Posted : Friday, February 10, 2017 6:31:21 AM(UTC)
Hi Elgarf
Yeah it works much better with a valid functions.xml.
However I noticed some "things"
- State Dependent works for some buttons but not all of them. It's ok for overlay toggle, but not for StartStreaming or StartRecording for example.
- SetMultiViewOverlay is OK unless we need an empty value for input (to remove one of the inputs in the multiview)
As soon as I use an empty field for an overlay, the small status led on the button turns red and most of the time UTC connection status LED also turns red.
Also there are 5 overlay possibilities in multiview, you only put 4 options in functions.xml. It's from 0 to 4 in API index, 1 to 5 in vMix GUI.
I added a 5th one in functions.xml. It's easy now!
- I'm a little confused with SetTextNative and SetImageNative. If I got it right I think you inverted these with regular SetText and SetImage.
So far when you used the term Native it's for internal UTC functions. But here Native seems to be for vMix. Is this what you wanted?
First I don't see any difference with SetText. Text indexes are always in 1st position, so Native or not, it's always the same index to use.
But for images, there is a difference. With SetImageNative, I must use the "image index" number as indicated by vMixAPI. With SetImage, I must use index number like before since you introduced the new state feature.
So basically, it works the opposite way I was expecting. But it works fine.
One more thing : what you call "title" for SetImage should be called "Index" I think. Title refers to xaml input. Here we must give the index number.
2 more observations:
- is it possible to invert state dependent colors? I asked about it before (if it was safe to do it 'cos I did it already)
I mean it would make more sense to have a red light when record or streaming are active. It is a standard. RED means ON...
- why not using StartStopRecording StartStopStreaming StartStopMultiCorder StartStopExternal instead of getting Start and Stop separate functions ?
I tried these, they work but the ActiveState is not happy. I always get a small red led in the buttons.
Here it is so far. Not tested the new MIDI feature yet...
Have a good day
Guillaume
elgarf
#267 Posted : Friday, February 10, 2017 7:07:27 AM(UTC)
elgarf
Russian Federation
1.
DWAM wrote:
Hi Elgarf
Looks like I broke state updating, but now it fixed. I'll update archive later.
Hmmm... UTC connection status should work Ok. BTW, I asked your log if connection status were again unstable for you.
Ok, I've added this too.
It must be swapped in theory byt I don't swap them because it breaks compatibility.
It is possible, but maybe I should make it configurable. I prefer GREEN as ON, like traffic lights. Maybe I should make GRAY is OFF and RED is ON. Or give user to select colors.
I'll try to make this. There is still problem, described in first question.
I made only StartStreaming/StopStreaming because of in early versions there wasn't indicator leds.
DWAM on 2/10/2017(UTC)
#268 Posted : Friday, February 10, 2017 8:35:26 AM(UTC)
Just sent you my log file for SetMultiviewOverlay issue.
I now understand better when/why it occurs, here's info on my multiview content :
background : color white
overlay 1 : other color input OR EMPTY (I have red light only when it's empty)
overlay 2 : NDI source (always on)
overlay 3 : xaml title OR EMPTY
overlay 4 : other xaml title OR EMPTY
I have these buttons:
button1 remove overlay1
button2 activates overlay1 with input
button3 removes overlay3
button4 activates overlay3 with input
button5 removes overlay4
button6 activates overlay4 with input
So now I understand that when overlay 1 is empty, UTC state gets wrong for all other overlays.
Same behaviour when overlay 3 is empty, 4 goes red
BTW it all works fine, only LED is wrong...
JAIRODJ
#269 Posted : Friday, February 10, 2017 5:04:19 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi Elgarf, congratulate you for the great work you've done
I was wondering if it is possible to incorporate in vMix UTC the function of obtaining the title of a vmix entry, and activate it by overlaying automatically at a certain time at the beginning of a video and at the end.
This is currently done using a powershell script that is in this section.
https://forums.vmix.com/default.aspx?g=posts&m=33043&#post33043
elgarf
#270 Posted : Sunday, February 12, 2017 2:07:16 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, at now there is no way to make this, maximum you can take name of the input by XmlDataProvider and put it to the title.
I think this task is for scheduler, but maybe someday I introduce full scripting into UTC. I'm thinking about IFStart/IFEnd commands for button scripts.
elgarf
#271 Posted : Tuesday, February 28, 2017 3:31:09 AM(UTC)
elgarf
Russian Federation
Hi! I've fixed updating recording/streaming/etc dependencies.
DWAM on 2/28/2017(UTC)
#272 Posted : Tuesday, February 28, 2017 6:06:23 AM(UTC)
Hi Elgarf
quick feedback with new version
- the small leds in buttons seem to be broken. Only when it checks vMix states. Buttons with internal functions work fine.
> a simple button with only an overlay toggle has red small led
- for all overlay functions, you define 5 overlay options from 0 to 4. Should be 1 to 4.
- the state dependent LEDS seem to be broken for some functions:
> with startstoprecording it's ok
> with an overlay toggle it's not
(I did not check them all)
- there is a small typo in start/stop MultiCoRder
- vMix 19 now supports 10 inputs on multiviews overlays
Will do more testing later
Guillaume
#273 Posted : Tuesday, February 28, 2017 6:27:37 AM(UTC)
I have also added 3 new functions since last time: Play, Pause and Restart Inputs. Take them if you want
Code:
    <Description>Play</Description>
    <Function>Play</Function>
    <FormatString>Function=Play&amp;Input={0}</FormatString>
    <IntDescription>N/A</IntDescription>
    <StringDescription>N/A</StringDescription>
    <Description>Pause</Description>
    <Function>Pause</Function>
    <FormatString>Function=Pause&amp;Input={0}</FormatString>
    <Description>Restart</Description>
    <Function>Restart</Function>
    <FormatString>Function=Restart&amp;Input={0}</FormatString>
elgarf
#274 Posted : Tuesday, February 28, 2017 6:45:31 AM(UTC)
elgarf
Russian Federation
@DWAM, ok, I fixed LEDs. Now all should be good.
Thank's for testing =)
#275 Posted : Tuesday, February 28, 2017 7:19:44 AM(UTC)
Thanks Elgarf, it seems everything's OK now.
I have one question
I'm having a countdown where format for field mapping is "m\ \m\i\n\u\t\e\s"
It works, but I would like "mm\ \m\i\n\u\t\e\s" (so that it shows "128 minutes" for example). But this doesn't work, when I indicate mm it won't show the word "minutes" anymore.
Any idea?
Guillaume
hak
#276 Posted : Tuesday, February 28, 2017 8:00:38 AM(UTC)
hak
Hi. How to add multicorder buttons, so I can start and stop recording for each input separately?
#277 Posted : Tuesday, February 28, 2017 8:15:52 AM(UTC)
There is no vMix API command to start or stop individual inputs in multicorder, so I don't think it's possible.
Maybe you can suggest a Feature Request for this?
hak on 3/1/2017(UTC)
#278 Posted : Thursday, March 2, 2017 5:26:23 AM(UTC)
Hi Elgarf
Feature request:
would it be possible to add an OnCompletion command for Timers Widget so that we can trigger something when time is elapsed and still keep the OnStop for other triggers.
For example I would like to be able to trigger "StartRecording" "OnCompletion" but not if I stop or reset the timer manually or from another button.
Or I would like to start a different Overtime Clock when Period Time is elapsed.
At the moment the OnStop command also triggers the Stop hotkey which is not convenient when it is set for other purpose.
Also do you think it's possible to have something that could do time calculation. For example "if countdown reaches 2 minutes before the end, do something"
One question
It works perfectly for 1 hour countdowns max , but I would like "mm\ \m\i\n\u\t\e\s" (so that it shows "128 minutes" for example). But this doesn't work, when I indicate mm it won't show the word "minutes" anymore, just 128.
спасибо
Guillaume
elgarf
#279 Posted : Thursday, March 2, 2017 7:24:17 AM(UTC)
elgarf
Russian Federation
@DWAM, I've updated UTC with On Completion timer widget link. Also there are all changes that I made for resolving crashes.
Time calculation is complex thing, it can be available when I make scripting function, but it's not even in near future.
When scripting will be available, I think you can just put some script in timer "On Tick" link.
I don't think that you should write text into timer format. Why you don't make another text field with "minutes" near minutes value?
DWAM on 3/2/2017(UTC)
#280 Posted : Thursday, March 2, 2017 9:52:11 AM(UTC)
Just gave it a try
Oncompletion works great for new timers but I think it broke compatibility with previous timers widgets in saved VMC projects.
Impossible to open a timer widget by clicking on the config icon, it makes UTC crash.
Sorry!
Remove the download link, there is no hurry for this.
Guest (19)
