puruzio
#1 Posted : Monday, February 11, 2013 9:18:53 PM(UTC)
puruzio
I'm planning to use a combination of a camcorder, AverMedia video capture PCI card (Avertv HD DVR High Definition / Analog Video Capture Card PCIe MTVHDDVRR installed on a desktop computer) and vMix to capture and mix a live video from our church service. I want to send the output to the TV in the room located away from the sanctuary. We currently already have a coaxial cable running between the camera and the TV, and since I now have vMix inbetween, I need to figure out how to put the computer between the camera and the TV.
http://www.vmix.com.au/h...and.html?search=decklink
The above link indicates I need another card for output, which makes sense. But can someone please let me know what is a good card to purchase for this purpose? Intensity Pro, Shuttle , Decklink.. are they different? Which is better?
guztavo
#2 Posted : Tuesday, February 12, 2013 12:18:19 PM(UTC)
guztavo
Hi puruzio!
In my case, i'm planning to buy a VGA to RCA adapter, to send the second video output of my video card to a TV (SD quality) over RCA (that allows a little more distance than HDMI or DVI cables).
Take a look: http://dx.com/p/ultimate...box-ntsc-pal-secam-28789
Hope it helps!
Regards from Argentina.
thanks 1 user thanked guztavo for this useful post.
puruzio on 2/17/2013(UTC)
kayllastudio
#3 Posted : Tuesday, February 12, 2013 12:46:57 PM(UTC)
kayllastudio
Was thanked: 12 time(s) in 7 post(s)
Graphics Card with TV Out can also be used connect to the tv / projector using coaxial cable
http://www.amazon.com/Sa...s-Graphics/dp/B001EC0224
thanks 1 user thanked kayllastudio for this useful post.
Kelvin
#4 Posted : Tuesday, February 12, 2013 5:55:04 PM(UTC)
Kelvin
I've use a VGA to Composite converter from Monoprice to do this exactly. Connected the VGA output from the graphics card to the converter. In my case, the composite output was connected to a high power microwave sender that sent the video signal over 600ft to a large JumboTron. It was an expensive setup, but made the event that much more enjoyable for the announcers and the crowd in attendance using the instant replay onsite.
http://www.monoprice.com...4&seq=1&format=2
thanks 1 user thanked Kelvin for this useful post.
