Newbie: external audio - add inputs for multi devices
Rank:: Member
Thanks: 12 times Was thanked: 1 time(s) in 1 post(s)
Using an external audio mixer, In vmix am I able to add an individual input for each audio device plugged into the external mixer? I presume it's not possible and that all audio devices connected to the external mixer can only have a single input assigned in vmix, meaning that multi audio devices must be controlled from the external mixer.
It depends on the mixer and other items in your setup. If your external audio mixer has lots of outputs (eg groups or direct channel outs) and your PC has lots of audio inputs from a multi-channel sound card (or multiple soundcards, or maybe a USB mixer which appears as a multi-channel recording device), then you can add lots of separate audio inputs in vMix, each one taking a different external audio source. However, a typical "USB Mixer" only gives you a single stereo audio recording device in Windows, equivalent to the Main Output.
 1 user thanked zenvideo for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 203 time(s) in 169 post(s)
 1 user thanked sinc747 for this useful post.
Rank:: Member
Many thanks guys, now it's clear. I have tried a Behringer Q1002 (usb) and also connected my Zoom H6 (line out). Of course only one channel appeared for each. Will need to think of an alternative mixer.
Rank:: Member
Looks promising @IceStream That guy has put together a nice portable unit!
David
Joined: 7/1/2016(UTC) Posts: 48  Location: Italy Thanks: 5 times Was thanked: 4 time(s) in 4 post(s)
Thanks,
The mixer has a integrated soundcard that can input every single channel on the mixer as vmix aufio device
Do your homework on the UFX1204. Reviews are mixed.
- Tom
