I'm not sure but I think there is a litte bug in the API if I call http://192.168.1.111:8088/api? I get <transitions> <transition number="1" effect="Fade" duration="250"/> <transition number="2" effect="Merge" duration="1000"/> <transition number="3" effect="Wipe" duration="1000"/> <transition number="4" effect="Fade" duration="1000"/> </transitions> Number 4 shows "Fade" but in vMix it's set to Stinger 1 what I'm doing wrong?
Same issue here but only when stinger 1 or 2 are selected for transition 4
All other transitions are reported correctly for transition 4
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Thanks for the report, we'll get this fixed in the next update.
this bug is also in Transition 1-3
