xaver
#1 Posted : Wednesday, March 1, 2017 8:04:54 AM(UTC)
xaver
I'm not sure but I think there is a litte bug in the API
if I call
http://192.168.1.111:8088/api?
I get
<transitions>
<transition number="1" effect="Fade" duration="250"/>
<transition number="2" effect="Merge" duration="1000"/>
<transition number="3" effect="Wipe" duration="1000"/>
<transition number="4" effect="Fade" duration="1000"/>
</transitions>
Number 4 shows "Fade" but in vMix it's set to Stinger 1
what I'm doing wrong?
#2 Posted : Wednesday, March 1, 2017 8:09:08 AM(UTC)
Same issue here but only when stinger 1 or 2 are selected for transition 4
All other transitions are reported correctly for transition 4
#3 Posted : Wednesday, March 1, 2017 9:58:22 AM(UTC)
Thanks for the report, we'll get this fixed in the next update.
xaver on 3/1/2017(UTC), madness on 3/1/2017(UTC)
xaver
#4 Posted : Wednesday, March 1, 2017 11:53:20 AM(UTC)
xaver
this bug is also in Transition 1-3
