Increasing/decreasing volume
Hello there,
I'm very new here and have already started using vMix.I have been looking for a solution to assign a key/keys to increase or decrease volume. I tried various things but all I could manage was mute or unmute function, which isn't something that I'm after.
If that's impossible using shortcuts on keyboard, I wonder if connecting to any other equipment, i.e. xkeys would do the trick?
Thanks in advance, Les
@ wczorajdzonson
Using the "SetVolume" function, you can assign a specific Value in percentage (i.e. 50% or 75% etc.) but there is no systematic lowering and/or raising function, just a direct move to that percentage value.
Joined: 2/24/2014(UTC) Posts: 45   Location: Maine, USA Thanks: 26 times Was thanked: 15 time(s) in 12 post(s)
As Ice mentioned, you can use "SetVolume" for a specific input or "SetMasterVolume" for the Master. You can change the volume incrementally by using "-=X" or "+=X" as the values (without the quotes, and "X" being the amount on a 0 - 100 scale to change the volume by). For instance, pressing a key 10 times with the value as "-=10" will take the volume from 100% to 0.
 1 user thanked DYosua for this useful post.
@DYosua: Can you please show me how to assign this to one key? Regards
I have attached an example for two keys - one to decrease the Master's volume, and the other which increases it. DYosua attached the following image(s):  SetMasterVolume.jpg (127kb) downloaded 58 time(s).You cannot view/download attachments. Try to login or register.
 2 users thanked DYosua for this useful post.
Perfect. Works magic! Thanks for great suggestions
Originally Posted by: DYosua  I have attached an example for two keys - one to decrease the Master's volume, and the other which increases it. Strangely, this works fine with keyboard shortcuts, but not as a function in a script. I mean the volume down (-=5) works in a function, but volume up (+=5) does not...
The script has to use Unicode coding for the (=, + and -)
= is 3D + is 2B - is 2D
Examples:
Function=SetPanX&Value=%2B%3D0.01&Input=24 Pans input 24 to the right for 0.01 units
Function=SetPanX&Value=%2D%3D0.01&Input=24 Pans input 24 to the left for 0.01 units
