wczorajdzonson
#1 Posted : Monday, February 27, 2017 5:58:30 PM(UTC)
wczorajdzonson
Hello there,
I'm very new here and have already started using vMix.I have been looking for a solution to assign a key/keys to increase or decrease volume. I tried various things but all I could manage was mute or unmute function, which isn't something that I'm after.
If that's impossible using shortcuts on keyboard, I wonder if connecting to any other equipment, i.e. xkeys would do the trick?
Thanks in advance,
Les
#2 Posted : Monday, February 27, 2017 6:12:17 PM(UTC)
Hi Les
the best way to control volume is to use faders or rotating buttons on a midi controller or joysticks.
Check http://www.vmix.com/help19/KeyboardShortcuts.html
and
Hope this helps
Guillaume
#3 Posted : Monday, February 27, 2017 7:44:46 PM(UTC)
@ wczorajdzonson
Using the "SetVolume" function, you can assign a specific Value in percentage (i.e. 50% or 75% etc.) but there is no systematic lowering and/or raising function, just a direct move to that percentage value.
DYosua
#4 Posted : Monday, February 27, 2017 7:48:49 PM(UTC)
DYosua
Was thanked: 15 time(s) in 12 post(s)
As Ice mentioned, you can use "SetVolume" for a specific input or "SetMasterVolume" for the Master. You can change the volume incrementally by using "-=X" or "+=X" as the values (without the quotes, and "X" being the amount on a 0 - 100 scale to change the volume by). For instance, pressing a key 10 times with the value as "-=10" will take the volume from 100% to 0.
thanks 1 user thanked DYosua for this useful post.
IceStream on 2/28/2017(UTC)
wczorajdzonson
#5 Posted : Tuesday, February 28, 2017 4:16:07 AM(UTC)
wczorajdzonson
@DYosua:
Can you please show me how to assign this to one key?
Regards
DYosua
#6 Posted : Tuesday, February 28, 2017 8:25:31 AM(UTC)
DYosua
I have attached an example for two keys - one to decrease the Master's volume, and the other which increases it.
DYosua attached the following image(s):
thanks 2 users thanked DYosua for this useful post.
azanisarri on 2/7/2019(UTC), Nandisha on 4/4/2026(UTC)
wczorajdzonson
#7 Posted : Tuesday, February 28, 2017 3:17:06 PM(UTC)
wczorajdzonson
Perfect. Works magic!
Thanks for great suggestions
ebjorno
#8 Posted : Thursday, February 7, 2019 2:33:08 AM(UTC)
ebjorno
Strangely, this works fine with keyboard shortcuts, but not as a function in a script. I mean the volume down (-=5) works in a function, but volume up (+=5) does not...
ebjorno
#9 Posted : Friday, September 20, 2019 6:49:26 PM(UTC)
ebjorno
The script has to use Unicode coding for the (=, + and -)
= is 3D
+ is 2B
- is 2D
Examples:
Function=SetPanX&Value=%2B%3D0.01&Input=24
Pans input 24 to the right for 0.01 units
Function=SetPanX&Value=%2D%3D0.01&Input=24
Pans input 24 to the left for 0.01 units
Guest (4)
