evilduck
#1 Posted : Saturday, February 25, 2017 7:53:35 AM(UTC)
evilduck
task:
4 hd-sdi inputs 1920x180@50i
1 hd-sdi out 1920x180@50i
1 sd-sdi out 720x576@50i
recording program in hd 1920x180@50i
can i achieve this with "DeckLink Duo 2" for 4 inputs and "DeckLink SDI 4K" for 2 independent outputs with different resolution simultaneously?
or recommend please best way
thank you
#2 Posted : Saturday, February 25, 2017 8:10:28 AM(UTC)
Was thanked: 795 time(s) in 589 post(s)
There's only one output with the DeckLink SDI 4K card
If you want to stick to BMD:
You can take 2 DeckLink Mini Monitor or 2 DeckLink Mini Monitor 4K instead.
Or 2 DeckLink Duo 2 (with up to 8 independently configurable inputs/outputs)
Or find older version of DeckLink Duo with 2 independently configurable inputs/outputs
Maybe DeckLink Quad 2 is also an option but some people seem to have problems with it.
Or consider the competition: Magewell, Aja, Yuang, etc...
evilduck
#3 Posted : Saturday, February 25, 2017 9:39:33 AM(UTC)
evilduck
yes, my mistake. thank you!
ok, but more important for me now to know: is it possible to get 2 sdi outputs with different resolution simultaneously?
#4 Posted : Saturday, February 25, 2017 9:53:35 AM(UTC)
with 4K and Pro version of vMix yes...
and I forgot to mention that you can also use HDMI output on your graphic card (along or as a replacement for a BMD card)
evilduck on 2/25/2017(UTC)
