2 outputs with different resolution simultaneously
task: 4 hd-sdi inputs 1920x180@50i 1 hd-sdi out 1920x180@50i 1 sd-sdi out 720x576@50i recording program in hd 1920x180@50i
can i achieve this with "DeckLink Duo 2" for 4 inputs and "DeckLink SDI 4K" for 2 independent outputs with different resolution simultaneously?
or recommend please best way
thank you
Joined: 3/20/2014(UTC) Posts: 2,719   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
There's only one output with the DeckLink SDI 4K card
If you want to stick to BMD: You can take 2 DeckLink Mini Monitor or 2 DeckLink Mini Monitor 4K instead. Or 2 DeckLink Duo 2 (with up to 8 independently configurable inputs/outputs) Or find older version of DeckLink Duo with 2 independently configurable inputs/outputs
Maybe DeckLink Quad 2 is also an option but some people seem to have problems with it.
Or consider the competition: Magewell, Aja, Yuang, etc...
yes, my mistake. thank you! ok, but more important for me now to know: is it possible to get 2 sdi outputs with different resolution simultaneously?
with 4K and Pro version of vMix yes... and I forgot to mention that you can also use HDMI output on your graphic card (along or as a replacement for a BMD card)
