cacooley
#1 Posted : Thursday, February 16, 2017 2:31:40 PM(UTC)
cacooley
I am, having issues getting a camera to display in widescreen in the software. I am using a Magewell XI100DUSB-HDMI adapter with a Sony SRG-300SE camera. It shows up fine in other capture software but not vmix. It comes in as a 4:3 aspect. I checked the settings of Vmix and I have output set to 1920 x 1080 and output aspect set to widescreen. Camera resolution is set to 1920 x 1080. Is there something else I am missing?
thanks in advance for any help
#2 Posted : Thursday, February 16, 2017 7:48:51 PM(UTC)
Was thanked: 795 time(s) in 589 post(s)
Hi
is it only vMix or all softwares ?
Did you try with VLC for example or Magewell USB Capture Utility ? Do you have the same issue with them?
Can you try this cam on another capture device in vMix ? As the case may be, what happens?
Len56
#3 Posted : Friday, February 17, 2017 9:48:45 AM(UTC)
Len56
Make sure when you add the camera via the camera input it is in the correct resolution i.e. 1920x1080 and the correct frame rate.
cacooley
#4 Posted : Saturday, February 18, 2017 8:05:14 PM(UTC)
cacooley
Thanks for all the replys. It is really weird because it shows and records fine in the Magewell capture utility. When I bring it into vMix it shows like a squished 4:3 aspect . When i look at a recording that I did in that way and go to the property of the clip it shows it is 1920 x 1080 but the aspect is 4:3. i verified the setttings of the camera output and they are all correct. At 1920 x 1080 output at 29.97 FPS. I will take some screen shots and post.
cacooley
#5 Posted : Saturday, February 18, 2017 8:47:45 PM(UTC)
cacooley
**Resolved**
I don't know what it was that was causing the issue but I decided to uninstall vMix, reboot and reinstall and it is fine now. Aspect is as it should be. Very strange.
Thanks again for all the replies.
