nicram
#1 Posted : Friday, February 17, 2017 9:18:08 AM(UTC)
nicram
I've installed vMix, now it's in tests :)
I've to produce video from pictures and add audio background to it.
As audio I have udp multicast stream and http stream but in vMix i can't add only audio input from stream :/
I've tried to transcode from vlc to vMIX using TS udp and TCP, but vMIX input needs both video and audio, but i've only audio stream.
How to add only audio input from stream?
#2 Posted : Friday, February 17, 2017 9:43:32 AM(UTC)
Hi
simply activate audio from your streams in the audio mixer
Check the doc :
http://www.vmix.com/help18/Mixer.html
nicram
#3 Posted : Friday, February 17, 2017 10:02:48 AM(UTC)
nicram
I know about mixer, but my problem is that i can't provide only audio stream (http://213.241.55.31:8866) as input.
#4 Posted : Friday, February 17, 2017 10:06:20 AM(UTC)
You can still add a black static image to audio when doing the transcode in VLC
nicram
#5 Posted : Friday, February 17, 2017 10:08:22 AM(UTC)
nicram
Hmm, good idea, but i don't see that posibility in vlc :/
#6 Posted : Friday, February 17, 2017 10:09:44 AM(UTC)
And also check NDI plugin for VLC which is a better and quicker way to ingest your stream in vMix
http://www.newtek.com/ndi/applications
#7 Posted : Friday, February 17, 2017 10:14:35 AM(UTC)
NDI is audio only capable so ingest your udp stream in VLC, setup VLC for NDI and add the NDI source in vMix.
Never tried myself but pretty sure it should work this way.
Keep us posted!
nicram
#8 Posted : Friday, February 17, 2017 10:22:25 AM(UTC)
nicram
Keep us posted!
Yes, this works :)
Thanks a lot
#9 Posted : Friday, February 17, 2017 10:32:21 AM(UTC)
Cool!
Have fun!
