Hi, I've installed vMix, now it's in tests :)
I've to produce video from pictures and add audio background to it. As audio I have udp multicast stream and http stream but in vMix i can't add only audio input from stream :/
I've tried to transcode from vlc to vMIX using TS udp and TCP, but vMIX input needs both video and audio, but i've only audio stream.
How to add only audio input from stream?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 794 time(s) in 589 post(s)
I know about mixer, but my problem is that i can't provide only audio stream (http://213.241.55.31:8866) as input.
You can still add a black static image to audio when doing the transcode in VLC
DWAM wrote:You can still add a black static image to audio when doing the transcode in VLC Hmm, good idea, but i don't see that posibility in vlc :/
NDI is audio only capable so ingest your udp stream in VLC, setup VLC for NDI and add the NDI source in vMix.
Never tried myself but pretty sure it should work this way.
Keep us posted!
DWAM wrote:NDI is audio only capable so ingest your udp stream in VLC, setup VLC for NDI and add the NDI source in vMix.
Keep us posted! Yes, this works :) Thanks a lot
