Greetings,
I've donated some time to a local animal shelter to try and fix one of their pet cams, and am running into more annoyances than I care to fix. They stream live feeds to their website which works fine from a laptop, but I'm trying to accomplish the same from an IP cam.
The part I can't get to work is the vmix > FMLE part. I have the IP cam streaming into vmix just fine. I also have FMLE working fine kicking to their site. The link I can't figure out is vmix to FMLE. FMLE gives me a choice of two vmix inputs, but both show color bars.
I assume there's an additonal string I have to set up in vmix under the stream tab at the bottom (RTMP?), but have no idea what it is. Id'd really appreciate the help on this.
Further request: I know how to use google, but I don't have a lot of time to dig through vague links to threads that really don't contain the answer. Would appreciate responses that focus on a solution given this goes to a good cause and I have limited time left to work on this project. Thanks
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Switch on "External" in vMix ?
