Hardware Compatibility
Decklink Quad 2 Duo only shows 4 inputs
Joined: 1/25/2017(UTC) Posts: 39 Location: Los Angeles
Thanks: 9 times Was thanked: 2 time(s) in 2 post(s)
Hello!
I have set up a new system from scratch, very excited to use 8 inputs.
Using Decklink Quad 2 Duo with 4/16 software downloaded from Blackmagic.
Inputs 1-4 are working, but when I try to add inputs 5-8, I get the error:
Error HRESULT E_FAIL has been returned from a call to a COM component.
Anyone experience this and know the solution?
Thanks!
Eliot Hochberg wrote:Hello!
Thanks! You have to set it up in the desktop video app. If you are not sure how to do it look here: http://documents.blackma...Desktop_Video_Manual.pdf
 1 user thanked ask for this useful post.
Your answer is right, but incomplete (I had found the solution before I saw your response). For anyone else with this issue, have a look here: http://www.vmix.com/know...k-quad2-to-be-8-channelsThis is why I hate hidden interface elements. I had no idea there were additional elements to scroll to, because there was no scroll bar. I needed to set the mapping of the ports (not sure why it isn't this way by default) so that each port goes with a unique connector, instead of in pairs.
