Problem with SetMultiViewOverlay
Hi
I'm trying to use API function "SetMultiViewOverlay".
As is, I understood this command only works when the desired multiview is in PREVIEW which is too bad. Is this correct?
- Would it be possible to use this API command when the multiview is in PROGRAM? - Would it even be possible to use this command when the chosen multiview is neither in PVW, nor in PGM ?
I guess to do so the query string should be something like:
http://vMixIP:8088/api/?Function=SetMultiViewOverlay&Input={InputIndex OR InputGUID}&Value={OverlayIndex},{InputNumber}
Please let me know if I missed something here... Or if I'd rather post this as a feature request.
Thanks Guillaume
DWAM wrote:this command only works when the desired multiview is in PREVIEW which is too bad. Is this correct? No Quote:Would it be possible to use this API command when the multiview is in PROGRAM? That is indeed possible Quote:Would it even be possible to use this command when the chosen multiview is neither in PVW, nor in PGM ? Absolutely The query string: http://localhost:8088/api/?Function=SetMultiViewOverlay&Input=4&Value=1,2 makes Input2 the source for Layer1 in Input4 (wether Input4 is in Program, Output or just hangs around ;)
Good! Thanks Richard... I should have tried before asking!
