#1 Posted : Wednesday, February 8, 2017 7:38:59 AM(UTC)
Hi
I'm trying to use API function "SetMultiViewOverlay".
As is, I understood this command only works when the desired multiview is in PREVIEW which is too bad. Is this correct?
- Would it be possible to use this API command when the multiview is in PROGRAM?
- Would it even be possible to use this command when the chosen multiview is neither in PVW, nor in PGM ?
I guess to do so the query string should be something like:
http://vMixIP:8088/api/?Function=SetMultiViewOverlay&Input={InputIndex OR InputGUID}&Value={OverlayIndex},{InputNumber}
Please let me know if I missed something here... Or if I'd rather post this as a feature request.
Guillaume
richardgatarski
#2 Posted : Wednesday, February 8, 2017 11:05:43 AM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
No
That is indeed possible
Absolutely
The query string:
http://localhost:8088/api/?Function=SetMultiViewOverlay&Input=4&Value=1,2
makes Input2 the source for Layer1 in Input4 (wether Input4 is in Program, Output or just hangs around ;)
#3 Posted : Wednesday, February 8, 2017 11:23:17 AM(UTC)
Good! Thanks Richard... I should have tried before asking!
