2 Pages<12
#21 Posted : Friday, February 3, 2017 12:22:17 PM(UTC)
Here
DWAM attached the following image(s):
#22 Posted : Friday, February 3, 2017 1:02:31 PM(UTC)
@ DWAM
Your observation and research skills are second to none.
Thanks for illustrating.
(I was looking primarily at the original attached image in the first post)
STADIORADIO
#23 Posted : Friday, February 3, 2017 1:47:52 PM(UTC)
STADIORADIO
I made all possible tests. driver update, test test.
Maybe it's time to upgrade to Windows 8 even if they are fond of window 7
#24 Posted : Friday, February 3, 2017 2:16:30 PM(UTC)
Did you check the graphic card is correctly inserted in the slot? Sometimes they can move a little...
Another test is to change the graphic card for a couple of days (if you've got another one at hand)...
And finally if you decide to update the OS, I suggest to move to W10 directly
STADIORADIO
#25 Posted : Monday, February 6, 2017 5:56:37 PM(UTC)
STADIORADIO
I solved the problem. I installed windows 8.1.
And the system must say that it seems faster and more stable
2 Pages<12
