Here DWAM attached the following image(s):  prova.png (91kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
@ DWAM
Your observation and research skills are second to none. Thanks for illustrating. (I was looking primarily at the original attached image in the first post)
Joined: 10/1/2013(UTC) Posts: 196  Location: Bovalino (Italy) Thanks: 86 times Was thanked: 3 time(s) in 3 post(s)
I made all possible tests. driver update, test test. Maybe it's time to upgrade to Windows 8 even if they are fond of window 7
Did you check the graphic card is correctly inserted in the slot? Sometimes they can move a little...
Another test is to change the graphic card for a couple of days (if you've got another one at hand)...
And finally if you decide to update the OS, I suggest to move to W10 directly
I solved the problem. I installed windows 8.1.
And the system must say that it seems faster and more stable
