pesi
#1 Posted : Tuesday, January 31, 2017 7:07:02 PM(UTC)
pesi
Canada
It would be extremely helpful to be able to duplicate inputs faster using right mouse-clicks (just like Wirecast) especially for the title inputs. This would help in creating new text titles on the fly at short notice during a live event.
#2 Posted : Tuesday, January 31, 2017 8:11:17 PM(UTC)
Hi Pesi
All inputs can be duplicated in 3 clicks max:
1 click on input gear icon
2 go first tab called General (if not already on it)
3 click create virtual input
You can create several duplicates in advance if you think you might need them
BTW regarding titles, if you can use duplicates (same xaml), I guess you should also consider using the "title preset" feature which allow to enter different values as a list of titles that you can then select with a single right-click.
Also you can use simple CSV files or data source to ingest values in your titles which is very quick.
Besides the web controller also allows to add titles on the fly...
http://www.vmix.com/help18/Title.html
pesi on 1/31/2017(UTC)
pesi
#3 Posted : Tuesday, January 31, 2017 8:22:13 PM(UTC)
pesi
Canada
DWAM wrote:
Hi Pesi
That's very true (and quick, thanks) but to be able to edit the text on those title dupes does not seem possible(?) - and would take much more doing ?
#4 Posted : Tuesday, January 31, 2017 8:53:39 PM(UTC)
If it's the same xaml title, you don't need to duplicate them, use "presets" instead
Title Presets
Click the + button to save the text from all the elements in the title as a preset.
This preset can be selected by right clicking the input in the main vMix window to recall these values at any time.
Title Presets can be Imported and Exported in CSV format using the Import and Export buttons
pesi
#5 Posted : Tuesday, January 31, 2017 9:01:10 PM(UTC)
pesi
Canada
No the titles would be different - e.g. a new presenter being suddenly announced without warning.
#6 Posted : Tuesday, January 31, 2017 9:07:42 PM(UTC)
That's exactly what I'm talking about
Once you have a lowerthird title for talents you can use the same for 1000 people if you need and select the right one with a single right click... Check carefully the doc and experiment... Use the + icon in title editor to add a name... You'll see how simple and powerful it is...
pesi
#7 Posted : Tuesday, January 31, 2017 9:39:52 PM(UTC)
pesi
Canada
got it! Thanks so much for all your help!
Pesi
