Hello dear team, i have download the vmix trial, and want buy it. Only one little info, i use only the streaming and the little call for create a picture of stream image by 8080 Snapshot every 5 min, and my resolution streaming is 864*486. i have to buy Basic HD, right? Thank you
@ pagu I am not familiar with the " little call for create a picture of stream image by 8080 Snapshot every 5 min" (or how to do that and why) but if you are not tied to the 864*486 resolution, I would suggest trying the FREE version first to see if it meets your needs and upgrade from there if necessary. If that "call" requires a script, then perhaps you are looking at acquiring vMix 4K or Pro. Feature Comparison List: http://www.vmix.com/purchase/Both the vVix Basic and Basic HD have considerable limitations compared to other Editions, but if your needs are simple, either one just might fit the bill... Ice Ice
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Using the "snapshot" shortcut could be used , maybe even with external little timer script to get an image each time (if i correctly understand the request)
with the pro or 4k version one could use the vMix scripting instead of external triggering
the program sharex could automate the screenshot process.
